Dialogic Audio Issues
I have a Dialogic jct120-ls and when a call is placed the card will answer the call and then the caller will hear no audio. This only happens on certain channels on the card and other channels work great. Any suggestions?
The card may be faulty...
[Log]
VoiceGuide=10
NumberLoader=0
VoicemailManager=0
EmailSender=0
TapiWrapOcx=10
SapiWrapOcx=0
Then make a test call which demonstrates the problem.
You can enable the automatic saving of the logs to files in \log\ directory as well.
