deanm Report post Posted 06/01/2006 06:31 AM Hi, We are running voice guide for dialogic on a d41JCT. I leave voice guide running for about a week making and receiving calls and every so often I notice lines staying permanently engaged. Sometimes all 4 of the lines stay engaged ie I cant dial in but according to voice guide it looks as though the lines are clear and ready to receive calls. I have run the trace log when this happens and tried making calls only to reciev an engaged signal and no action is recorded in the trace logs. The only way to fix the problem is to close voice guide and restart it, then all the phone lines clear and inbound and outbound calls can be made. This has become regular now, it happens about every 1-2 weeks and it means sometimes customers cant get through to our system. Your help is appreciated Regards Dean Share this post Link to post
SupportTeam Report post Posted 06/01/2006 04:01 PM Which version of VoiceGudie are you using? What version of Window are you using? If the callers get an engaged signal then it means that the phone company did not recognise the Dialogic card hanging up at end of call. Please post some traces capturing the 24 hours or so before this problem occurs, then we can see if there are any errors shown there. Share this post Link to post
deanm Report post Posted 06/20/2006 01:34 AM Hi, I have managed to replicate the problem and capture a trace of it. Somone calls in Press to transfer Announced transfer to a mobile phone. Person who makes the call hangs up Then mobile hangs up. Line still remains connected. See attached screen shot and event trace Running Voiceguide for dialogic Version 6.0.2332 on Window 2000 professional Your help is appreciated. Regards Dean Error_Voiceguide.doc Share this post Link to post
SupportTeam Report post Posted 06/21/2006 12:56 PM Running Voiceguide for dialogic Version 6.0.2332 Please update to current version (v6.0.3107 currently) and see if the problems still occur on your system with this new version. Share this post Link to post
deanm Report post Posted 06/26/2006 07:23 AM Please remind me to Install a new version. Do I need to do all of these steps if not which ones do I do To update VoiceGuide to the "for Dialogic" version you will then need to: 1. Place Config.xml and ConfigLine.xml in VG's \data\ subdirectory 2. Place ktTelControl.ocx, MsComm32.ocx and libexpat.dll in Windows' \System32\ subdirectory 3. Place VgMulti.exe, VgGsd.exe, VgDialer.exe and VgLv.exe in VG's main directory, overwriting previous files. 4. Open a DOS Command Window. (Start->Programs->Accessories->Command Prompt) Change to Windows' \System32\ subdirectory using command: cd c:\Windows\System32 and run the following commands: regsvr32 -u tapiwrap.ocx regsvr32 ktTelControl.ocx regsvr32 MsComm32.ocx Share this post Link to post
SupportTeam Report post Posted 06/29/2006 12:18 PM If updating to new version of VG for Dialoigc then you just need to do this: 1. run the following command: regsvr32 -u ktTelControl.ocx 2. Place new ktTelControl.ocx in Windows' \System32\ subdirectory, overwriting previous files. 3. Place VgMulti.exe, VgGsd.exe, VgDialer.exe and VgLv.exe in VG's main directory, overwriting previous files. 4. run the following command: regsvr32 ktTelControl.ocx Share this post Link to post
deanm Report post Posted 07/13/2006 04:43 AM I have installed the new version of voice guide and it now errors run time error 449 Argument not optional. This is the log 250 142409.55 0 ERROR 6.0.3107 dial DbFindDueCall_MSAccess [Too few parameters. Expected 1.] line=210 142409.55 0 ERROR 6.0.3107 dial DbFindDueCall_MSAccess [Object variable or With block variable not set] line=250 142409.55 0 ERROR 6.0.3107 dial DbFindDueCall_MSAccess [Too few parameters. Expected 1.] line=210 142409.55 0 ERROR 6.0.3107 dial DbFindDueCall_MSAccess [Object variable or With block variable not set] line=250 What is goin on? Share this post Link to post
SupportTeam Report post Posted 07/13/2006 12:58 PM 142409.55 0 ERROR 6.0.3107 dial DbFindDueCall_MSAccess [Too few parameters. Expected 1.] line=210 142409.55 0 ERROR 6.0.3107 dial DbFindDueCall_MSAccess [Object variable or With block variable not set] line=250 Stop VG, then delete file OutDial.mdb in VG's \data\ subdirectory, then restart VG. I have installed the new version of voice guide and it now errors run time error 449 Argument not optional. Ensure you do not have the old version of ktTelControl.ocx on the system. Maybe best to just re-install from scratch. ie. uninstall first & delete all of VG - backing up your scripts first - and then re-install VG and apply the 'VG for Dialogic' patch (newest). Share this post Link to post
