Guest Cardguys Report post Posted 06/02/2006 06:56 PM we are considering purchasing this program. Basically we are held up by only a few concerns. It is probably best that I describe what my company will be doing. Telephun has been asked to work with trivia manufacturers to produce a phone number where callers can compete by answering questions. Instead of re-inventing the wheel, we decided to search out an interface that would be capable of performing some of the following functions. 1) Maintaining 2+ callers in the same queue at the same time. (Similar to a party line) 2) Handling multiple incoming calls. I.E. routing callers to one queue and concomitantly routing other callers to a different queue. 3) handling internet calls. Share this post Link to post
SupportTeam Report post Posted 06/06/2006 09:51 AM 1) Maintaining 2+ callers in the same queue at the same time. (Similar to a party line) 2) Handling multiple incoming calls. I.E. routing callers to one queue and concomitantly routing other callers to a different queue. VoiceGuide can be setup to do that. 3) handling internet calls. You need to get the VoIP<->Analog converter from your VoIP supplier (most supply it when you order the VoIP line from them) and then plug the analog output into the Dialogic card. Share this post Link to post
