Syntax To Access Result Variables From Another Script
Can someone tell me the correct syntax I need to use in my CLEANUP.VGS script which is run when I detect a caller hang up.
My main script (APP1.VGS) is running and has done a DB lookup which has created the result variable $RV[DB_Lookup_Module_1_1] and then the caller hangs up. I want to access this in CLEANUP.VGS so do I need to just use the syntax :
$RV[DB_Lookup_Module_1_1] in CLEANUP.VGS,
...or do I need to specify the script the RV came from?
Anyone know the answer?
Cheers
Simon
$RV[DB_Lookup_Module_1_1] should work.
Have you tried it?
No.
