Using User Input
What is needed in my script once the caller enters the phone number?
I would like to retreived the phone number and then write it out to an Excel spreadsheet or Access database. Presently I'm trying it with Excel. Can someone instruct me on the syntax necessary to accomplish this? I've tried some of the examples but I've been unsucessful. Will I need to use a third party package to accomplish this? or can this all be done with VG?
What is the syntax to execute a read or a write to and from a file?
Should I use CT Media instead?
Any suggestions would be helpful.
This is the output from the event trace log.
54687 5 tapie linedevstate 2048 0 0
54687 5 tapie callstate OFFERING 66169 0 4
54703 5 tapie callinfo CALLEDID
54703 5 tapie callinfo ORIGIN
54703 5 tapie ring 0
54703 5 Answer the call
54703 5 lineAnswer(66169) => 66118
55250 5 tapie callstate CONNECTED 66169,1,0
55250 5 WorkingModeTAPI=
55250 5 WorkingModeScript=
55281 5 Inband detection not enabled
55281 5 tapi Reply 66118 0
55281 5 [begin] Playing
55281 5 [begin] Playing (C:\Program Files\VoiceGuide\Scripts\newbeginintro.wav)
55296 5 PlaySoundStart ok [C:\Program Files\VoiceGuide\Scripts\newbeginintro.wav]
55296 5 RunModule PLAY end
76234 5 tapie monitordigits 49 2
76234 5 LsPlayMsg [1]
76281 5 PlaySoundStop ok
76281 5 [MBcompinfo] Playing
76281 5 [MBcompinfo] Playing (C:\Program Files\VoiceGuide\Scripts\newbizintro.wav)
76312 5 PlaySoundStart ok [C:\Program Files\VoiceGuide\Scripts\newbizintro.wav]
76312 5 RunModule PLAY end
91281 5 tapie monitordigits 49 2
91281 5 LsPlayMsg [1]
91328 5 PlaySoundStop ok
91328 5 [MBcallerentry] Number Input
91343 5 [MBcallerentry] Playing (C:\Program Files\VoiceGuide\Scripts\placenumber.wav)
91359 5 PlaySoundStart ok [C:\Program Files\VoiceGuide\Scripts\placenumber.wav]
06671 5 wb(69134300)
06718 5 Play End line[5] (id=691343)
06734 5 LsGetNbrsPlayWelcMsg EV_PLAY_FINISHED
07734 5 tapie monitordigits 54 2
07734 5 LsGetNbrsRxDigits [6]
07734 5 [MBcallerentry] Number Input 6
08125 5 tapie monitordigits 51 2
08125 5 LsGetNbrsRxDigits [3]
08125 5 [MBcallerentry] Number Input 63
10968 5 tapie monitordigits 48 2
10968 5 LsGetNbrsRxDigits [0]
10968 5 [MBcallerentry] Number Input 630
12937 5 tapie monitordigits 57 2
12937 5 LsGetNbrsRxDigits [9]
12937 5 [MBcallerentry] Number Input 6309
13343 5 tapie monitordigits 53 2
13343 5 LsGetNbrsRxDigits [5]
13343 5 [MBcallerentry] Number Input 63095
13781 5 tapie monitordigits 53 2
13781 5 LsGetNbrsRxDigits [5]
13796 5 [MBcallerentry] Number Input 630955
14359 5 tapie monitordigits 56 2
14359 5 LsGetNbrsRxDigits [8]
14359 5 [MBcallerentry] Number Input 6309558
14609 5 tapie monitordigits 55 2
14609 5 LsGetNbrsRxDigits [7]
14609 5 [MBcallerentry] Number Input 63095587
15078 5 tapie monitordigits 54 2
15078 5 LsGetNbrsRxDigits [6]
15078 5 [MBcallerentry] Number Input 630955876
15609 5 tapie monitordigits 57 2
15609 5 LsGetNbrsRxDigits [9]
15609 5 [MBcallerentry] Number Input 6309558769
15609 5 fn PlaySoundStartNumbers C:\Program Files\VoiceGuide\system\voicedlgc\GetNbrsConfirmIntro.wav, C:\Program Files\VoiceGuide\system\voicedlgc\GetNbrsConfirmMenu.wav, 6309558769, Digits
15625 5 twcal PlaySayNumber C:\Program Files\VoiceGuide\system\voicedlgc\GetNbrsConfirmIntro.wav, C:\Program Files\VoiceGuide\system\voicedlgc\GetNbrsConfirmMenu.wav, 6309558769, , 1
15656 5 PlaySoundStartNumbers ok
32015 5 Play End line[5] (id=715625)
32015 5 LsGetNbrsPlayConfirm EV_PLAY_FINISHED
44406 5 tapie monitordigits 51 2
44406 5 LsGetNbrsPlayConfirm [3]
44421 5 PlaySoundStop ok
44421 5 [MBcallerentry] Number Input
44421 5 [MBcallerentry] Playing (C:\Program Files\VoiceGuide\Scripts\placenumber.wav)
44421 5 PlaySoundStart ok [C:\Program Files\VoiceGuide\Scripts\placenumber.wav]
55000 5 tapie monitordigits 55 2
55000 5 LsGetNbrsPlayWelcMsg [7]
55046 5 PlaySoundStop ok
55046 5 [MBcallerentry] Number Input 7
55453 5 tapie monitordigits 55 2
55453 5 LsGetNbrsRxDigits [7]
55453 5 [MBcallerentry] Number Input 77
56468 5 tapie monitordigits 51 2
56468 5 LsGetNbrsRxDigits [3]
56468 5 [MBcallerentry] Number Input 773
57937 5 tapie monitordigits 50 2
57937 5 LsGetNbrsRxDigits [2]
57937 5 [MBcallerentry] Number Input 7732
58343 5 tapie monitordigits 56 2
58343 5 LsGetNbrsRxDigits [8]
58343 5 [MBcallerentry] Number Input 77328
58578 5 tapie monitordigits 55 2
58578 5 LsGetNbrsRxDigits [7]
58578 5 [MBcallerentry] Number Input 773287
58921 5 tapie monitordigits 51 2
58921 5 LsGetNbrsRxDigits [3]
58921 5 [MBcallerentry] Number Input 7732873
59640 5 tapie monitordigits 55 2
59640 5 LsGetNbrsRxDigits [7]
59640 5 [MBcallerentry] Number Input 77328737
59968 5 tapie monitordigits 54 2
59968 5 LsGetNbrsRxDigits [6]
59968 5 [MBcallerentry] Number Input 773287376
60203 5 tapie monitordigits 53 2
60203 5 LsGetNbrsRxDigits [5]
60203 5 [MBcallerentry] Number Input 7732873765
60203 5 fn PlaySoundStartNumbers C:\Program Files\VoiceGuide\system\voicedlgc\GetNbrsConfirmIntro.wav, C:\Program Files\VoiceGuide\system\voicedlgc\GetNbrsConfirmMenu.wav, 7732873765, Digits
60218 5 twcal PlaySayNumber C:\Program Files\VoiceGuide\system\voicedlgc\GetNbrsConfirmIntro.wav, C:\Program Files\VoiceGuide\system\voicedlgc\GetNbrsConfirmMenu.wav, 7732873765, , 1
60250 5 PlaySoundStartNumbers ok
76093 5 wb(76021811)
76140 5 Play End line[5] (id=760218)
76140 5 LsGetNbrsPlayConfirm EV_PLAY_FINISHED
85031 5 tapie monitordigits 49 2
85031 5 LsGetNbrsPlayConfirm [1]
85031 5 PlaySoundStop ok
85031 5 [Exit-Goodbye] Playing
85031 5 [Exit-Goodbye] Playing (C:\Program Files\VoiceGuide\Scripts\newgoodbye.wav)
85062 5 PlaySoundStart ok [C:\Program Files\VoiceGuide\Scripts\newgoodbye.wav]
85062 5 RunModule PLAY end
88140 5 Play End line[5] (id=785046)
88140 5 LsPlayMsg EV_PLAY_FINISHED
88140 5 LsPlayMsgFinished EV_TIMEOUT_GOTOMODULE
88140 5 [Run Program 7] Run Program
88140 5 Run Program Failed, err[5:Invalid procedure call or argument] running[C:\Program Files\VoiceGuide\data\VGRUNRESULT_1.TXT]
88156 5 HangupCall called from [Run module 2369]
88156 5 Hanging up call...
88156 5 PlaySoundStop ok
88156 5 fnHangupCall end
88203 5 tapie linedevstate 2048 0 0
88203 5 tapie callstate IDLE 66169 0 0
88203 5 WorkingMode@Idle=
88203 5 set EV_TIMEOUT_TIMETOREINITLINE 2
88203 5 tapi Reply 66219 0
89265 5 LsAwaitingCalls EV_TIMEOUT_TIMETOREINITLINE
89265 5 ReinitTelephony due to IDLE start
89265 5 tapic lineDeallocateCall(MainCall:66169) 0
89406 5 lineOpen(5) => 0
89406 5 Waiting for a call...
89406 5 lineOpen(5)LineHandle=66236
Thanks!
Retrieving and setting data from/to Excel spreadsheets can be done quite easily using the Run VB Script module.
The following examples show how to work with Access.
You will need to look at other samples to see how to use Result Variables and how to return data to VoiceGuide from VB Script.
From VoiceGuide Help file ("Modules -> Run VB Script" section)
Example 6:
The VB Script below retrieves information from an Excel spreadsheet.
Dim xlApp 'Excel.Application
Dim xlBook 'Excel.Workbook
dim xlSht
Dim filename, value1, value2, value3, value4
filename = "c:\Warehouse.xls"
Set xlApp = CreateObject("Excel.Application")
set xlBook = xlApp.WorkBooks.Open(filename)
set xlSht = xlApp.activesheet
value1 = xlSht.Cells(2, 1)
value2 = xlSht.Cells(2, 2)
msgbox "Values are: " & value1 & ", " & value2
xlBook.Close False
xlApp.Quit
Set xlBook = Nothing
Set xlApp = Nothing
Example 7:
The VB Script below saves information to an Excel spreadsheet.
dim xlSht
on error resume next
filename = "c:\warehouse.xls"
xlApp.DisplayAlerts = False
'write data into the spreadsheet
xlSht.Cells(2, 2) = "New Data"
xlBook.Save
xlBook.Close SaveChanges=True
xlApp.Close
xlApp.Quit
set xlSht = Nothing
Set xlApp = Nothing
