Srlib Play Soundstart Error
I got the above error on only 1 line where on all the other 3 lines everything is working perfectly, here's the event log:
025203.01 10 devstate NUMCALLS 0 0
025203.03 10 tapi callstate start
025203.03 10 tapi callstate OFFERING 67244 0 4
025203.03 10 callinfo CALLEDID
025203.03 10 callinfo ORIGIN
025203.03 10 ring 0
025203.13 0 dial start any summary:|7:idx=0|8:idx=0|9:idx=0|10:hc>0|
025209.03 10 ring 2
025209.03 10 rv clear
025209.03 10 Answer the call at 6/14/2006 2:52:09 AM
025209.03 10 lineAnswer(67244) => 66264
025209.56 10 tapi callstate start
025209.56 10 tapi callstate CONNECTED 67244 1 0
025209.56 10 callstate CONNECTED 67244,1,0
025209.58 10 WorkingModeTAPI@Connected=
025209.58 10 WorkingModeScript@Connected=
025209.58 10 Inband detection not enabled
025209.58 10 StartLoadedVgs at 6/14/2006 2:52:09 AM, script interpretor VgMulti v5.2.5012 7
025209.58 10 rv ns add [scriptsPath]{C:\Program Files\VoiceGuide\Scripts\BonhamsIVRUS\}
025209.59 10 rv ns add [scriptPath]{C:\Program Files\VoiceGuide\Scripts\BonhamsIVRUS}
025209.59 10 rv lg add [$RV_STARTTIME]{6/14/2006 2:52:09 AM}
025209.59 10 rv lg add [$RV_DEVICEID]{10}
025209.59 10 rv lg add [$RV_CIDNAME]{}
025209.59 10 rv ns add [PathApp]{C:\Program Files\VoiceGuide\}
025209.59 10 rv lg add [$RV_CIDNUMBER]{}
025209.59 10 rv lg add [$RV_DNIS]{}
025209.59 10 rv lg add [DNIS]{}
025209.61 10 tapi Reply (LineEvReply) ok 66264 0
025209.61 10 callinfo MONITORMODES
025209.61 10 timer clear
025209.61 10 state [Welcome] Playing
025209.61 10 state [Welcome] Playing (SoundFiles\Bonhams1.wav)
025209.61 10 play set playid=-875125
025209.63 10 PlaySoundStart err=[0 play PlaySoundStart ResetWavOutAndContinuePlay=>32,play pss EnsureWaveOutIsOpenAndReady=>wavec waveOutOpen(0x377d2ac, 0x4, 0x377d278, 0x501d0, 0x377d250, 0x10006) => 32 (WAVERR_BADFORMAT) ... hli->hWaveOut=0x0] [C:\Program Files\VoiceGuide\Scripts\BonhamsIVRUS\SoundFiles\Bonhams1.wav]
025209.63 10 path {WAVERR_BADFORMAT} not found
025209.63 10 play set playid=-875125
025209.63 10 PlaySoundStart err=[0 play PlaySoundStart ResetWavOutAndContinuePlay=>32,play pss EnsureWaveOutIsOpenAndReady=>wavec waveOutOpen(0x377d2ac, 0x4, 0x377d278, 0x501d0, 0x377d250, 0x10006) => 32 (WAVERR_BADFORMAT) ... hli->hWaveOut=0x0] [C:\Program Files\VoiceGuide\system\voice\ErrorPlayingFile.wav]
025209.63 10 For Dialogic use: PCM 11Khz 8bit Mono
025209.63 10 rv lg add [Hangup Time]{6/14/2006 2:52:09 AM}
025209.64 10 state Hanging up call... [srlib PlaySoundStart]
025209.64 10 RecSoundStop ok
025209.64 10 PlaySoundStop err=0
025209.64 10 timer set 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP
025209.64 10 fnHangupCall end
025209.64 10 RunModule PLAY end
025209.64 10 play end current play (playid=0)
025209.66 10 ScriptEventCode 8001 iLineState=900
025209.66 10 LsAwaitingCalls EV_PLAY_FINISHED
025209.66 10 play end current play (playid=0)
025211.59 10 devstate NUMCALLS 0 0
025211.61 10 tapi callstate start
025211.61 10 tapi callstate IDLE 67244 0 0
025211.61 10 WorkingMode@Idle=
025211.61 10 timer clear
025211.61 10 timer set 1 EV_TIMEOUT_TIMETOREINITLINE
025211.61 10 tapi Reply (LineEvReply) ok 66033 0
025212.61 10 timer fired EV_TIMEOUT_TIMETOREINITLINE
025212.61 10 ScriptEventCode 9008 iLineState=900
025212.61 10 LsAwaitingCalls EV_TIMEOUT_TIMETOREINITLINE
025212.61 10 ReinitTelephony due to IDLE
025212.61 10 tapic lineDeallocateCall(MainCall:67244) 0
025212.67 10 lineOpen(10)=>
025212.67 10 state Waiting for a call...
025212.67 10 LineHandle=66158
025212.67 10 amchk set AMdet=False in Reinit@idle
025212.67 10 timer set 3 EV_TIMEOUT_ATERIDLE_ALLOWOUT
025213.13 0 dial start any summary:|7:idx=0|8:idx=0|9:idx=0|10:rdy=0|
025215.97 10 timer fired EV_TIMEOUT_ATERIDLE_ALLOWOUT
025215.97 10 ScriptEventCode 9013 iLineState=900
025216.13 0 dial start any summary:|7:idx=0|8:idx=0|9:idx=0|10:idx=0|
Not sure whether it's a driver problem but if so then how come everything is working on the other 3 lines?
Many thanks.
Trace shows Wave driver is returning WAVERR_BADFORMAT.
Are you using a Dialogic card? You should be using "VG for Dialogic" if you do. Wave drivers are unreliable.
