Multi Language Number Speaking - Different Logic
I could almost succesfully implement using English and Chinese by using DIRSYSTEMVOICE result variable. However, in the Speak number module I want VG to say the number – but the logic of the two languages to interpret the number is different. E.g 123456 – Chinese says: Twelve_TenThousand_ThreeThousand_FourHundred_FiveTen_Six
I know I need to modify lib_num2wav script for the Chinese– but I need English and Chinese at the same time.
As I can create 2 system voice folders for the two languages, I should be able to create two system folders or two lib_num2wav files – one for each language or some conditions inside lib_num2wav. What is the solution? So if the caller chooses English, they hear the number in English language and English way of saying numbers; if they choose Chinese they hear it in Chinese language and in Chinese logic. I have already have the necessary sound files.
I tried to modify the lib_num2wav file by adding a condition with a result variable:
If $RV[Language] = 1 Then
End if
Also tried "$RV[Language]". Either there was an error during the call or the module said "zero" instead of the number.
The $RV[Language] variable worked well in VG modules but I cannot use it in the lib_num2wav file.
So how can i manage the different algoritm in different languages?
Editing lib_num2wav.vbs is the right approach.
Are you setting $RV[Language] in a script before running the SayNumbers module?
Have you tried:
If "$RV[Language]" = "1" Then
Have you tried:
Yes I defined $RV[Language] earlier in the script and the speak number module works well in English if I do not place
If "$RV[Language]" = "1" Then etc. inside the lib_num2wav file - that is, if I use the original file.
The problem is that $RV[Language] is not replaced by the actual number in the lib_num2wav file!!!
I have checked the automatically created vbs_4_SayNumber vbscript file in C:\Program Files\VoiceGuide\data and it shows no replacement.
The result variables are replaced correctly in every module but not in the lib_num2wav file.
If I omit the " " around the result variable then the script gives error because of the $ sign.
I suspect that it is the VG software problem. Haven't you forgotten to provide the result variable replacement in lib_num2wav file???? Just test it!
When I use the VBscript for creating the Chinese wav files in a VBS module + Play file module both the Chinese and English works well.
[Log]
VoiceGuide=10
NumberLoader=0
VoicemailManager=0
EmailSender=0
TapiWrapOcx=0
SapiWrapOcx=0
Please post the traces and the VoiceGuide script used as well as the vbs_4_SayNumber vbscript file and your modified lib_num2wav file.
A few times it worked but most of the times it freezed VG or the line hung up when it should say the number.
It created 2 files: vbs_3_rr_SayNumber and vbs_3_SayNumber. All attached.
vgm0623.zip
The attached new version should fix the problem you encountered.
To update to new versions do:
1. stop VG
2. run in C:\Windows\System32\ (at command prompt):
regsvr32 -u ktTelControl.ocx
3. make backup of ktTelControl.ocx (onto a floppy or other machine on
network - do not just rename it)
4. copy new ktTelControl.ocx to C:\Windows\System32\
5. run in C:\Windows\System32\ (at command prompt):
regsvr32 ktTelControl.ocx
6. copy new VgMulti.exe to VG's directory. (make backup first).
Now you can run the test calls again.
vg_6.0.0.3120.zip
