Disconnect Tone
Hello,
The attached file is a disconnect tone file. The problem I have to analysis this disconnect tone is, there are 4 frequencies tones: 1399, 2060, 2499 and 2600.
I am not sure which one should I use?
Thanks for your advice.
Farzad
newlingotone.wav
Just stick with the two lowest ones: 1400 and 2060
This is a very strange busy/disconnect tone, the frequences in tone are usually much lower and more distict.
Have you tried speaking with the telphone company to confirm is that is what theya re intentionally sending? It almost seems as if it is a problem with their equipment...
bellow are the configrations I found. would you please let me know which one should I use.
F1 1400
Freq1 dev: 140
F2 2060
Freq2 dev: 200
on time 10
On Dev 5
Off time 10
Off Dev 5
rep 2
F1 1400
Freq1 dev: 140
F2 0
Freq2 dev: 0
on time 10
On Dev 5
Off time 10
Off Dev 5
rep 2
F1 2060
Freq1 dev: 200
F2 0
Freq2 dev: 0
on time 10
On Dev 5
Off time 10
Off Dev 5
rep 2
F1 2060
Freq1 dev: 200
F2 1400
Freq2 dev: 140
on time 10
On Dev 5
Off time 10
Off Dev 5
rep 2
The first one would be the one to use...
As mentioned before this is a very unusual tone so not use what the detection reliability would be...
This tone is generate at the time VoIP phone is disconnected from internet.
The problem we have is, in middle east the internet service is not reliable, it suddenly disconnected; when VoIP Phone is disconnected from internet, however other party disconnect the phone, our line is still busy, because VG can not recognize this tone to disconnect the line.
thanks for your advice.
Is the Dialogic card unable to detect that tone when using the frequency/cadence definition as per previous post? Or does it detect it unreliably?
I am using VG for Dialogic software. The disconnect tone would be enter into the configline.xml file.
However we enter the attached tone promoters into the configline.xml. The VG or Dialogic card can not recognize it.
Do you think I can use voice recognizer software? I am thinking, if I can program Voice recognizer the way when it hear this tone, it generate a digit between 1 to 9, then I can program VG to hang-up the line when it got any digit between 1 to 9.
What "voice recognizer" are you referring to?
