Zoltan Report post Posted 06/21/2006 08:51 AM In the VBS module I assembly a series of wav files. How can i play them in the VBS module directly without exporting this wav files name string by a result variable into a Play Sound File module? I am not talking about background music. In the help file you have an example sndrec32 /play /close c:\test.wav that can be used in a Run Another Program module. Do you have a solution for VBS module, too? Share this post Link to post
SupportTeam Report post Posted 06/21/2006 01:13 PM Do you want to play these sound files on the phone line, or on the PC speaker? If over the phone line then have you looked at the Play_Start COM command? If over PC speaker then look at the VBScript Shell command. Share this post Link to post
