Guest Erik Report post Posted 07/16/2003 07:50 PM Can I change the playback device? I have multiple audio cards and would like to use a particular one for playback. Share this post Link to post
SupportTeam Report post Posted 07/17/2003 01:55 AM To play a sound file over the PC speaker please see the examples in the Run Program module: Example 3: The Run Program module can be used to play a sound file to attract attention, eg: when the customer has selected to speak with someone live. You can run the Sound Recorder application specifying that it should play the specified sound file and then close afterwards using this command line: sndrec32 /play /close c:\test.wav The Media Player application can also be used for this purpose: mplayer /play /close c:\test.wav If you are finding that the program does not run as VoiceGuide cannot find it then try specifying the full path to where your program is on your system. For example, the Media Player program on some systems is actually in: C:\Program Files\Windows Media Player\mplayer2.exe which would make the actual command line required to be used in the Run Module: C:\Program Files\Windows Media Player\mplayer2.exe /play /close c:\test.wav Share this post Link to post
