'timeout 0' Not Working In Play Module
I seem to have a problem in a Play module where the timeout 0 path is not taken immediately. Strangely it is working fine earlier in the script.
Please see module StudyIDProblemPlay
Attached is the log and script. Please see call at 11:14.
I am using VG 5.2.5049 Professional.
The script was not attached, so here it is now.
logs.zip
Randomisation_fff.txt
It's because you're replaying the wav 3 times with 5 seconds in between.
[studyIDProblemPlay]
Type=Play
DispSize=69
Txt=Play "There was a problem obtaining the StudyID, we will investigate ..."
PlayFile1=StudyIDProblem.wav
Replay=2,5
strTtsText=
on {timeout 0} goto [inviteVMFinal]
on {1} goto [inviteVMFinal]
