metra Report post Posted 06/27/2006 01:12 PM We have implemented on our server the Comisdn SIP communication Server and configured Voice Guide to use two ISDN lines and two SIP lines. Voice Guide answers on all lines but when we call over an SIP line, TTS generation of wav files is not processed. Here are two extracts of the log file : ISDN call : 112941.86 10 timer clear 112941.86 10 state [ML_Direct_DemIdent] Number Input 112941.86 10 lineAnswer(66087) => 65591 112941.86 10 tapi Reply (LineEvReply) ok 65591 0 LineCallState=OFFERING 112941.88 dial start any summary:|10:hc>0|11:ivd<0|12:idx=0|13:ivd<0|14:idx=0|15:idx=0| 112941.94 10 tapi callstate CONNECTED 66087 1 0 112941.95 10 callstate CONNECTED 66087,1,0 112941.95 10 WorkingModeTAPI@Connected=Answering 112941.95 10 WorkingModeScript@Connected=BeforeAnswerRun 112941.95 10 Inband detection not enabled 112941.95 10 timer clear 112941.95 10 state [ML_Direct_DemIdent] Number Input 112941.95 10 rv replace start: [TTS\ML_Direct_DemIdent_$RV[Langue].txt] 112941.95 10 rv ns [PathSysVoice]{C:\Program Files\VoiceGuide\system\voice\}[PathApp]{C:\Program Files\VoiceGuide\}[PathDataVm]{C:\Program Files\VoiceGuide\data\}[PathVgSys]{C:\Program Files\VoiceGuide\system\}[scriptsPath]{E:\VoiceGuide\Script\}[scriptPath]{E:\VoiceGuide\Script}[$RV_STARTTIME]{27.06.2006 11:29:41}[$RV_DEVICEID]{10}[$RV_CIDNAME]{}[PathApp]{C:\Program Files\VoiceGuide\}[$RV_CIDNUMBER]{0272037215}[$RV_DNIS]{3005374}[DNIS]{3005374}... 112941.95 10 rv replace end: [TTS\ML_Direct_DemIdent_F.txt] 112941.95 10 rv replace start: [$RV[LangDebTag] $RV[ErrMessage].Attention ! Serveur de test. Les données ne sont pas conservées. Bonjour! Et bienvenue sur le serveur vocal de Mède-Lineque. Merci de taper votre numéro d'identification suivi de la touche dièse. $RV[LangFinTag] ] 112941.97 10 rv ns [PathSysVoice]{C:\Program Files\VoiceGuide\system\voice\}..... 112941.97 10 rv replace end: [<Voice required="Language=40c"> .Attention ! Serveur de test. Les données ne sont pas conservées. Bonjour! Et bienvenue sur le serveur vocal de Mède-Lineque. Merci de taper votre numéro d'identification suivi de la touche dièse. </voice> ] 112941.97 10 tts generate start[<Voice required="Language=40c"> .Attention ! Serveur de test. Les données ne sont pas conservées. Bonjour! Et bienvenue sur le serveur vocal de Mède-Lineque. Merci de taper votre numéro d'identification suivi de la touche dièse. </voice> ] 112941.98 10 tts generate wait 112942.41 10 tts generate finish. lineCallState=CONNECTED 112942.41 10 amchk test AMdet in TtsToWavFileFinished => False 112942.41 10 rv replace start: [TTS\ML_Direct_DemIdent_$RV[Langue].txt] 112942.41 10 rv ns [PathSysVoice]{C:\Program Files\VoiceGuide\system\voice\}[PathApp]{C:\Program Files\VoiceGuide\}[PathDataVm]{C:\Program Files\VoiceGuide\data\}[PathVgSys]{C:\Program Files\VoiceGuide\system\}[scriptsPath]{E:\VoiceGuide\Script\}[scriptPath]{E:\VoiceGuide\Script}[$RV_STARTTIME]{27.06.2006 11:29:41}[$RV_DEVICEID]{10}[$RV_CIDNAME]{}[PathApp]{C:\Program Files\VoiceGuide\}[$RV_CIDNUMBER]{0272037215}[$RV_DNIS]{3005374}[DNIS]{3005374}... 112942.41 10 rv replace end: [TTS\ML_Direct_DemIdent_F.txt] 112942.41 10 state [ML_Direct_DemIdent] Playing (C:\Program Files\VoiceGuide\temp\tts_10_1.wav) 112942.42 10 play set playid=819421 112942.45 10 PlaySoundStart ok [C:\Program Files\VoiceGuide\temp\tts_10_1.wav] IP call : 112333.56 14 timer clear 112333.56 14 state [ML_Direct_DemIdent] Number Input 112333.56 14 lineAnswer(65710) => 66514 112333.56 14 tapi Reply (LineEvReply) ok 66514 0 LineCallState=OFFERING 112405.63 14 tapi callstate DISCONNECTED 65710 2 0 112405.63 14 ScriptEventCode 9250 iLineState=5900 112405.63 14 rv lg add [Hangup Time]{27.06.2006 11:24:05} 112405.63 14 state Hanging up call... [LsModuleTransition] 112405.63 14 HangupCall_Common Mode=BeforeAnswerRun 112405.63 14 tapi callstate IDLE 65710 0 0 112405.63 14 WorkingMode@Idle= 112405.63 14 timer clear 112405.63 14 WriteToLogFiles_CurrScriptOnly start 112405.63 WriteToLogFiles_DoWrite start (E:\VoiceGuide\Script\MLmenuP) 112405.64 14 After Hangup script:[MLAfterHangUp.vgs] 112405.64 0 LoadedVgs_Find E:\VoiceGuide\Script\MLAfterHangUp.vgs at idx=7 112405.64 14 callinfo NUMMONITORS 112405.64 14 timer clear Looking in the sw log file, there is no traces for TTS generation when called over the IP line. I join complete log files of this event. Where is the problem ? Is it possible to use Voige Guide in a mixed configuration ? Does Voice Guide supports IP lines ? Thank you in advance for answers. Pierre Métrailler Log files joined : - 0627 0627vgm_ISDN.txt 0627vgm_IP.txt 0627sw.txt 0627tw.txt Share this post Link to post
SupportTeam Report post Posted 06/29/2006 12:29 PM The problem is not with TTS generation, the problem here is that the TAPI driver for the SIP case is not advising VG that the call is CONNECTED. You should speak to ComISDN about why this is not happening. Share this post Link to post
