The "100 Bug" In Lib_num2wav, Hundreds2wav Function
In the lib_num2wav script : hundreds2wav(ByVal AmountToSay) function there is a bug.
If the number to say ends with 100, 200, 300 etc., an unnecessary comma will be added after the hundred.wav file.
The problem is in this line, which is close to the end:
Result = Result & "," & s2_WavList
s2_WavList is empty in case of 100, 200 etc.
Furthermore, if the number is e.g. 300400 the extra comma problem comes after each hundred file
Here is my solution : add the foolowing condition around the Result = .... line
If s2_WavList <> "" Then
End If
Have you found that that extra comma affects things? Or is it just basically ignored with the next specified file being played?
It did not cause any trouble and I fixed the problem for myself. I had two commas next to each other in a sequence of wav files. I do not know, however, whether it can cause problems for others in other situations.
Two (or more) commas should not cause a problem. VG should skip over the unspecified file(s) and play the next file in the sequence.
