Issues Using Using Variables In Paths Of Evaluation Module
I am trying to call a subscript from a evaluation module and using RV variables in the call and return statement it is not working due to some reason the script is not returing to the correct module
here is a log
1 event ScriptEventCode *, code=42, state=1100
195450.88 1 LsPlayMsg *,*
195450.89 1 play PlaySoundStop ok
195450.91 1 rv add [Welcome]{*}
195450.91 1 fn RunModule start
195450.92 1 tw DialogicEvent 134,TDX_CST,42,0,0,DE_DIGITS,,
195450.92 1 event ScriptEventCode TDX_CST, code=134, state=6001
195450.94 1 tw PlayEnd 1 46625
195450.94 1 play end id=46625, (current ID)
195450.95 1 event ScriptEventCode EV_PLAY_FINISHED, code=8001, state=6001
195450.95 1 tw DialogicEvent 129,TDX_PLAY,46625,0,0,,,
195450.97 1 event ScriptEventCode TDX_PLAY, code=129, state=6001
195450.97 1 timer clear
195450.98 1 state [startMessageRec] Evaluate [$RV_PreviousModule]
195450.98 1 rv replace start: [$RV_PreviousModule]
195451.00 1 rvns [PathSysVoice]{C:\Program Files\VoiceGuide\system\voice\}[PathApp]{C:\Program Files\VoiceGuide\}[PathDataVm]{C:\Program Files\VoiceGuide\data\}[PathVgSys]{C:\Program Files\VoiceGuide\system\}[$RV_STARTTIME]{7/3/2006 7:54:42 PM}[$RV_DEVICEID]{1}[$RV_CIDNAME]{}[PathApp]{C:\Program Files\VoiceGuide\}[scriptsPath]{D:\VoiceScripts\}[$RV_CIDNUMBER]{}[GetLang]{1}[Welcome]{*}
195451.00 1 rv replace end: [Welcome]
195451.02 1 eval[Welcome]
195451.02 1 rvns add [startMessageRec_Input]{Welcome}
195451.03 1 rvns add [startMessageRec]{Welcome}
195451.03 1 rvns add [WAVFILE]{Welcome}
195451.05 1 Eval Expr result:[Welcome] stored in $RV[WAVFILE]
195451.05 1 rv replace start: [on {true} gosub [D:\VoiceScripts\RecMessage.vgs|AskRecord] return [ $RV_PreviousModule ]
on {false} gosub [D:\VoiceScripts\RecMessage.vgs|AskRecord] return [ $RV_PreviousModule ]
on {timeout 0} gosub [D:\VoiceScripts\RecMessage.vgs|AskRecord] return [ $RV_PreviousModule ]
I dont see a rv replace end here
195451.06 1 rvns [PathSysVoice]{C:\Program Files\VoiceGuide\system\voice\}[PathApp]{C:\Program Files\VoiceGuide\}[PathDataVm]{C:\Program Files\VoiceGuide\data\}[PathVgSys]{C:\Program Files\VoiceGuide\system\}[$RV_STARTTIME]{7/3/2006 7:54:42 PM}[$RV_DEVICEID]{1}[$RV_CIDNAME]{}[PathApp]{C:\Program Files\VoiceGuide\}[scriptsPath]{D:\VoiceScripts\}[$RV_CIDNUMBER]{}[GetLang]{1}[Welcome]{*}[startMessageRec_Input]{Welcome}[sta
tMessageRec]{Welcome}[WAVFILE]{Welcome}
195451.08 1 path {Welcome} not found
195451.08 1 stack idx=1
195451.09 1 rv add [scriptStart_Time]{7/3/2006 7:54:51 PM}
195451.09 1 rv add [scriptStart_CalledFrom_Script]{D:\VoiceScripts\Shamel.vgs}
195451.11 1 rv add [scriptStart_CalledFrom_Module]{StartMessageRec}
195451.11 1 FindFullPathToScript_VgsOrVgp start [D:\VoiceScripts\RecMessage.vgs]
195451.13 1 FindFullPathToScript_VgsOrVgp 1
195451.13 0 LoadedVgs_Find D:\VoiceScripts\RecMessage.vgs at idx=1
195451.14 1 rvns add [scriptsPath]{D:\VoiceScripts\}
195451.14 1 fn RunModule start
195451.16 1 timer clear
And here are the paths in the calling module
