Unable To Make Outbounds Calls
I have a Dialogic D/4PCIU card, running SP6.0PCI under Windows XP Professional SP2.
I installed Voice Guide 5.2.5049 (trial version) then followed the instructions to migrate to VG for Dialogic (in Help-About VoiceGuide it now shows version 6.0.3107).
I can make inbound calls and the call can be recorded using script Answer & Record.
But I am not able to make outbound calls.
For each line, the box "Allow VoiceGuide to dialout on this line" is ticked/enabled.
When I pull up the Telephone Numbers Loader (v5.2.1027) and add a number into the Phone Numbers box, press Load Numbers it comes up underneath this button with "Finished queued :0 rejected:1".
Any ideas ??
[Log]
VoiceGuide=0
NumberLoader=10
VoicemailManager=0
EmailSender=0
TapiWrapOcx=0
SapiWrapOcx=0
Then start the Telephone Numbers Loader and try loading some numbers.
Debug Trace files will be created in VG's \log\ subdirectory.
Please post the traces.
Hi
I updated vg.ini as indicated and started the Telephone Numbers Loader.
I added one tel number but it came back with the same response as stated on my initial posting.
I have tried to use winrar to compress the debug trace file but I was not allowed to attach the file to this note.
Below is a copy of the entry in the file - the lines are repeated over and over again, all details the same:
220350.55 0 ---------------------------------------------------
220350.56 0 VoiceGuide for Dialogic
220350.58 0 v6.0.3107
220350.58 0 ---------------------------------------------------
220356.58 0 ERROR 6.0.3107 dial DbFindDueCall_MSAccess [Too few parameters. Expected 1.] line=210
220356.59 0 ERROR 6.0.3107 dial DbFindDueCall_MSAccess [Object variable or With block variable not set] line=250
220356.59 0 ERROR 6.0.3107 dial DbFindDueCall_MSAccess [Too few parameters. Expected 1.] line=210
220356.61 0 ERROR 6.0.3107 dial DbFindDueCall_MSAccess [Object variable or With block variable not set] line=250
220356.61 0 ERROR 6.0.3107 dial DbFindDueCall_MSAccess [Too few parameters. Expected 1.] line=210
HK
Stop VG and exit the Telephone Number Loader, then delete file OutDial.mdb in VG's \data\ subdirectory, then restart VG.
Hi
I deleted the OutDial files and it worked, outbound calls are go !! Thanks !!
Only one glitch - I am using the standard Dial And Record.vgs script to record the conversation once the line is picked up but the message "AM - wait for end of welcome message" is displayed and the recording does not start until the end of the voice message has been played.
How can I set it to record the response as soon as the line is picked up (to include any voice message) ?
Do you know if I need to amend the script or is a setting on the Dialogic card itself ?
HK
Got it - thanks for all your help on this Support team.
VG is capable of doing everything I require, which having tried 5 other applications is no small thing.
Cheers
HK
