Cannot Access Variables Created By Rvset_rvlist Or Rvset
I have a vbscript that when run, will check into a database for a list of active phone numbers, and then one by one, using vg.Dialer_MakeCall, ask voiceguide to call these lines up and record for a while.
This is to test that the lines are up and running.
When vg dials into the line to test it for me, I first need to give it a password to authenticate the call, then a firther 4 digit number that directs the call to the particular Live line that I am testing.
I am using recorded dtmf tones to pass these values.
So VG will dial these phone lines (another VG system actualy!), and play the dtmf tones required to authenticate itself, then start recording the intro for about 10 seconds before hanging up and trying the next line. This all works fine if i hard code the sound file path (for the DTMF) tones into the VG script. However i need to pass the names of these sound files in from the orginal vb script that starts and manages this whole process. But any variables passed in by the vb script dont seem to be accessable by voice guide.
To get vg to dial the phone system, i use:
LineId = vg.Dialer_MakeCall("310", "", "", "C:\Program Files\VoiceGuide\Scripts\Test1900Lines.vgs")
Then to pass in the particular passwords i use either
vg.RvSet LineId, "Pin1", "C:\Program Files\VoiceGuide\1900SystemTesting\0.wav"
Or
vg.RvSet_RvList LineID, Return1 (return1 being a list of name value pairs)
Voiceguide seems to do this fine, and the log shows that the vars are being added as follows:
152803.86 5 cl RvSet Pin1, C:\Program Files\VoiceGuide\1900SystemTesting\0.wav
152803.86 5 rv add [Pin1]{C:\Program Files\VoiceGuide\1900SystemTesting\0.wav}
However when i go to use the var to play a sound file i get:
[Play0005Tones] Playing
152814.88 5 RVreplace start: [$RV[Pin1]]
152814.88 5 RVns [OutDial_Result]{Contacted_Human}[scriptEnd_Time]{27/07/2006 3:28:10 PM}[scriptEnd_Goto_Script]{C:\Program Files\VoiceGuide\Scripts\Test1900Lines.vgs}[scriptEnd_Goto_Module]{}[scriptStart_Time]{27/07/2006 3:28:10 PM}[scriptsPath]{C:\Program Files\VoiceGuide\Scripts\}
152814.88 5 RVreplace end: []
152814.88 5 [Play0005Tones] Playing ()
It has added the variable Pin1, so why cant i get it back.
PLease find below the entire log trace.
152803.86 0 cl Dialer_MakeCall 310, , , C:\Program Files\VoiceGuide\Scripts\Test1900Lines.vgs
152803.86 0 Search for free lines in range [5-12]
152803.86 5 Calling 310
152803.86 5 TimeoutSet 3600 EV_TIMEOUT_HANGUP
152804.41 5 tapi Reply (LineEvReply) ok 66012 0
152804.41 5 linedevstate 2048 0 0
152804.41 5 callstate DIALTONE 65674 0 0
152804.41 5 callstate DIALING 65674 0 0
152804.41 5 callstate PROCEEDING 65674 0 0
152804.41 5 callinfo CALLEDID
152804.41 5 callinfo REASON
152804.41 5 Lev_CallerID [0000,]
152804.41 5 callinfo ORIGIN
152810.91 5 callstate CONNECTED 65674,1,0
152810.91 5 WorkingModeTAPI@Connected=
152810.91 5 WorkingModeScript@Connected=
152810.92 5 rv add [$RV_STARTTIME]{27/07/2006 3:28:10 PM}
152810.92 5 rv add [$RV_DEVICEID]{5}
152810.92 5 rv add [$RV_CIDNAME]{}
152810.92 5 AddRVns [PathApp]{C:\Program Files\VoiceGuide\}
152810.92 5 rv add [$RV_CALLEDNUMBER]{310}
152810.92 5 AddRVns [OutDial_Result]{Contacted_Human}
152810.92 5 Live person answered, starting C:\Program Files\VoiceGuide\Scripts\Test1900Lines.vgs
152810.92 2 tr NewVgsVgm_Goto C:\Program Files\VoiceGuide\Scripts\Test1900Lines.vgs,,,,,0
152810.92 5 rv add [scriptEnd_Time]{27/07/2006 3:28:10 PM}
152810.92 5 rv add [scriptEnd_Goto_Script]{C:\Program Files\VoiceGuide\Scripts\Test1900Lines.vgs}
152810.94 5 rv add [scriptEnd_Goto_Module]{}
152810.94 5 rv add [scriptStart_Time]{27/07/2006 3:28:10 PM}
152810.94 0 LoadedVgs_Find C:\Program Files\VoiceGuide\Scripts\Test1900Lines.vgs at idx=6
152810.94 5 AddRVns [scriptsPath]{C:\Program Files\VoiceGuide\Scripts\}
152810.94 5 cl NewVgsVgm_RunModule module not found:
152810.94 2 tr NewVgsVgm_Goto 1
152810.94 2 tr NewVgsVgm_Goto 2
152810.94 5 TimeoutClear
152810.94 5 [Play1594Tones] Playing
152810.94 5 [Play1594Tones] Playing (C:\Program Files\VoiceGuide\1900SystemTesting\1594.wav)
152810.97 5 PlaySoundStart ok [C:\Program Files\VoiceGuide\1900SystemTesting\1594.wav]
152810.97 5 TimeoutClear
152810.97 5 RunModule PLAY end
152810.97 2 tr NewVgsVgm_Goto end
152810.97 5 wa(1712,90565600)
152810.97 5 callinfo MONITORMODES
152812.73 5 wb(90565600)
152812.78 5 Play End line[5] (id=905656)
152812.78 5 ScriptEventCode 8001 iLineState=1100
152812.78 5 LsPlayMsg EV_PLAY_FINISHED
152812.78 5 TimeoutSet 10 EV_TIMEOUT_HANGUP
152812.78 5 TimeoutSet 2 EV_TIMEOUT_GOTOMODULE
152814.88 5 Timer fired EV_TIMEOUT_GOTOMODULE
152814.88 5 ScriptEventCode 9002 iLineState=1101
152814.88 5 LsPlayMsgFinished EV_TIMEOUT_GOTOMODULE
152814.88 5 TimeoutClear
152814.88 5 ScriptEventCode 8001 iLineState=1100
152814.88 5 LsPlayMsg EV_PLAY_FINISHED
152814.88 5 TimeoutSet 10 EV_TIMEOUT_HANGUP
152814.88 5 TimeoutSet 0 EV_TIMEOUT_GOTOMODULE
152814.88 5 [TurnOffSilence] Evaluate [0]
152814.88 5 .Eval(0)
152814.88 5 AddRVns [TurnOffSilence_Input]{0}
152814.88 5 AddRVns [TurnOffSilence]{0}
152814.88 5 AddRVns [silenceDetectLvl]{0}
152814.88 5 Eval Expr result:[0] stored in $RV[silenceDetectLvl]
152814.88 5 SilenceDetectSet(5, 30, 0)
152814.88 5 [RecordLine] Recording
152814.88 5 rv add [RecordLine]{C:\Program Files\VoiceGuide\1900SystemTesting\systest.wav}
152814.89 5 RecSoundStart file[C:\Program Files\VoiceGuide\1900SystemTesting\systest.wav] ok
152814.89 5 RecFile[C:\Program Files\VoiceGuide\1900SystemTesting\systest.wav]
152814.89 5 TimeoutSet 10 EV_TIMEOUT_GOTOMODULE
152814.89 5 RunModule PLAY end
152819.77 5 callstate DISCONNECTED 65674,0,0
152819.77 5 ScriptEventCode 9250 iLineState=1201
152819.77 5 LsRecRecording EV_REMOTEPARTY_DISCONNECT
152819.83 5 RecSoundStopTruncBytes ok
152819.83 5 rec length RV: RecordLine_RecLen100ms = 49
152819.83 5 rv add [RecordLine_RecLen100ms]{49}
152819.83 5 rv add [RecordLine_EndRecCause]{disconnect}
152819.83 5 rv add [Hangup Time]{27/07/2006 3:28:19 PM}
152819.83 5 Hanging up call... [During LsRecRecording]
152819.83 5 RecSoundStop ok
152819.83 5 PlaySoundStop err=0
152819.83 5 TimeoutSet 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP
152819.83 5 fnHangupCall end
152819.83 5 ScriptEventCode 8003 iLineState=900
152819.83 5 LsAwaitingCalls EV_REC_FINISHED
152819.86 5 linedevstate 2048 0 0
152819.86 5 callstate IDLE 65674 0 0
152819.86 5 WorkingMode@Idle=
152819.86 5 TimeoutClear
152819.88 5 TimeoutSet 1 EV_TIMEOUT_TIMETOREINITLINE
152819.88 5 tapi Reply (LineEvReply) ok 66396 0
152820.92 5 Timer fired EV_TIMEOUT_TIMETOREINITLINE
152820.92 5 ScriptEventCode 9008 iLineState=900
152820.92 5 LsAwaitingCalls EV_TIMEOUT_TIMETOREINITLINE
152820.92 5 ReinitTelephony due to IDLE
152820.92 5 tapic lineDeallocateCall(MainCall:65674) 0
152821.06 5 lineOpen(5)=>
152821.06 5 Waiting for a call...
152821.06 5 LineHandle=66340
152821.06 5 TimeoutSet 3 EV_TIMEOUT_ATERIDLE_ALLOWOUT
Have you tried using Dialer_OutDialAdd instead of Dialer_MakeCall?
You can specify RVs to be used throughout the outgoing call when using Dialer_OutDialAdd.
Another approach would be to only set the RVs after the call has been answered.
It looks like when doing a Dialer_MakeCall the RVs get cleared at connect time - so any settings made before that using RvSet/etc are erased. Dialer_MakeCall was only really intended to make the call for the second leg of a "Dial and Conferece" type transfer.
This would be a great solution, I mucked around and worked it all out, then realised that the machine it needs to run on (one of 3 voiceguide machines here) is the only one without a dialer license installed.
So I really need to use the MakeCall com.
Any way of stopping the variables being cleared?
Ben Harper
No way that I can see to stop them being cleared - it would require modifications of the software itself.
Not sure which version of VG you are running on these systems, but usually the call to Dialer_MakeCall whould fail unless the Dialer license is installed...
