Guest enadhazeem Report post Posted 08/24/2006 07:34 PM I used to get the event trace log automatically. What do I have to do to turn it on. Thanks Share this post Link to post
SupportTeam Report post Posted 08/24/2006 10:45 PM Enable logging by setting the log levels to 10 in VG.INI as per below: [Log] VoiceGuide=10 NumberLoader=0 VoicemailManager=0 EmailSender=0 TapiWrapOcx=10 SapiWrapOcx=0 Then restart VG and make a test call which demonstrates the problem. Debug Trace files will be created in VG's \log\ subdirectory. Share this post Link to post
Guest enadhazeem Report post Posted 08/25/2006 05:54 AM Please note that I am using VoiceGuide for Dialogic 6.0.3107. When I tried to modify vg.ini I received a message that states that VoiceGuide has not yet been configured and the program would not start vguide.bmp Share this post Link to post
SupportTeam Report post Posted 08/25/2006 06:39 AM When installing VoiceGuide for Dialogic you need to follow installation instructions in the README.TXT file in the .ZIP archive. Share this post Link to post
