Event Trace Log
I used to get the event trace log automatically. What do I have to do to turn it on.
[Log]
VoiceGuide=10
NumberLoader=0
VoicemailManager=0
EmailSender=0
TapiWrapOcx=10
SapiWrapOcx=0
Please note that I am using VoiceGuide for Dialogic 6.0.3107. When I tried to modify vg.ini I received a message that states that VoiceGuide has not yet been configured and the program would not start
When installing VoiceGuide for Dialogic you need to follow installation instructions in the README.TXT file in the .ZIP archive.
