Not Detecting Dial Tone Or Ringback
We are using Voiceguide version 6.0.3141
We are using a Dialogic D/4 PCI card.
Attached are two traces:
2006 08 23 Good Call.txt This trace represents a call made with the phone line connected and call
is successful. (Included only for reference)
2006 08 23 No Phone Line.txt This trace represents a call made with the phone line disconnected,
however voiceguide calls and believes a human answers.
We expected the On Not Connected script to run when the line was not connected, however this is not the case.
For some reason we occasionally lose dialtone after calling and must unplug and replug the line to the dialogic card. If this is not done all calls made after losing dialtone will complete even though no calls are made.
How can we detect when the line is not connected or no dialtone and act on this information?
Phone_Traces.zip
Please update your system with version 6.0.3149 available for download in this support forum thread:
http://voiceguide.com/forums/index.php?showtopic=4165
v6.0.3149 will detect the phone line is unplugged and the call will fail.
You should be able to insert dial tone modifiers in the telephone number dial string to force the Dialogic card to wait for dial tone before proceeding with Dialing. The modifies are "L", "I" and "X" as per below:
L - listen for Local dial tone.
I - listen for International dial tone.
X - listen for Special dial tone.
If using these you should define the corresponding tones in the LineConfig.xml file.
Since updating we have had mixed results, it seems that voiceguide occasionally will stop calling or it will dial and hangup before any answer. Included below is a trace where the error line not plugged in occurs (line is plugged in and working), however, if you press hangup from voiceguide it will start making the next call.
=133 state=5200
104504.48 1 LsWaitAfterDialingOut : 133,CONNECT,10,3,0,CR_CNCT,CON_PVD,
104504.48 1 event CON_PVD, iCode=133 state=5200
104504.48 1 LsWaitAfterDialingOut : 133,CON_PVD,10,3,0,CR_CNCT,CON_PVD,
104504.50 1 event CR_CNCT, iCode=133 state=5200
104504.50 1 LsWaitAfterDialingOut : 133,CR_CNCT,10,3,0,CON_PVD,,
104504.50 1 event TDX_CALLP, iCode=133 state=5200
104504.50 1 LsWaitAfterDialingOut : 133,TDX_CALLP,10,3,0,CR_CNCT,CON_PVD,
104504.50 1 LineEvCallState_OutgoingCallWasAnswered 10,3,0
104504.50 1 init OnCallAnswered_StartScript start
104504.50 1 init StartLoadedVgs_InitLineState start
104504.52 1 rv add [$RV_STARTTIME]{9/8/2006 10:45:04 AM}
104504.52 1 rv add [$RV_DEVICEID]{1}
104504.52 1 rv add [$RV_CIDNAME]{}
104504.52 1 rvns add [PathApp]{C:\Program Files\VoiceGuide\}
104504.52 1 WARN rv ScriptsPath could not be set as LineState(iLineId).iVgsIdx = 0 in StartLoadedVgs_InitLineState
104504.52 1 rv add [$RV_CALLEDNUMBER]{12703822368}
104504.53 1 set LineState().hCall = 643046 in OnCallAnswered_StartScript
104504.53 0 dial callque delete id=55 (MSAccess)
104504.53 1 rvns add [OutDial_Result]{Contacted_Human}
104504.53 1 state Live person answered, start [c:\Recall4u\Scripts\DemoDialing\ReminderCall.vgs]
104504.53 1 tr NewVgsVgm_Goto (c:\Recall4u\Scripts\DemoDialing\ReminderCall.vgs,,,,,0)
104504.53 1 rv add [scriptEnd_Time]{9/8/2006 10:45:04 AM}
104504.55 1 rv add [scriptEnd_Goto_Script]{c:\Recall4u\Scripts\DemoDialing\ReminderCall.vgs}
104504.55 1 rv add [scriptEnd_Goto_Module]{}
104504.55 1 rv add [scriptStart_Time]{9/8/2006 10:45:04 AM}
104504.55 1 rv add [scriptStart_CalledFrom_Module]{ReminderHangup}
104504.55 1 FindFullPathToScript_VgsOrVgp start [c:\Recall4u\Scripts\DemoDialing\ReminderCall.vgs]
104504.55 0 LoadedVgs_Find c:\Recall4u\Scripts\DemoDialing\ReminderCall.vgs at idx=3
104504.56 1 rvns add [scriptsPath]{c:\Recall4u\Scripts\DemoDialing\}
104504.56 1 StartModuleDefault=[ReminderHuman]
104504.56 1 fn RunModule start [Play,[ReminderHuman],28,,]
104504.56 1 timer clear
104504.56 1 Play Module start
104504.56 1 state [ReminderHuman] Playing
104504.56 1 state [ReminderHuman] Playing (C:\Recall4U\Scripts\DemoDialing\Remind.wav)
104504.58 1 tw ConvertWav2Vox C:\Recall4U\Scripts\DemoDialing\Remind.wav
104504.58 2 tr NewVgsVgm_Goto end
104504.58 1 tw wav->vox convert end 643125,C:\Recall4U\Scripts\DemoDialing\Remind.vox,1,0,,
104504.61 1 play start ok, lPlayId=643125
104507.22 1 tw PlayEnd 1 643125
104507.23 1 play end id=643125, (current ID)
104507.23 1 event EV_PLAY_FINISHED, iCode=8001 state=1100
104507.23 1 LsPlayMsg EV_PLAY_FINISHED,EV_PLAY_FINISHED
104507.23 1 path {EV_PLAY_FINISHED} not found
104507.23 1 timer set 10 EV_TIMEOUT_HANGUP
104507.23 1 timer set 0 EV_TIMEOUT_GOTOMODULE
104507.25 1 event EV_TIMEOUT_GOTOMODULE, iCode=9002 state=1101
104507.25 1 LsPlayMsgFinished EV_TIMEOUT_GOTOMODULE,EV_TIMEOUT_GOTOMODULE
104507.25 1 path {EV_TIMEOUT_GOTOMODULE} not found
104507.25 1 next module is [ReminderPlayClinicName] (idx=43)
104507.25 1 fn RunModule start [Play,[ReminderPlayClinicName],43,,]
104507.25 1 tw DialogicEvent 129,TDX_PLAY,643125,0,0,,,
104507.25 1 event TDX_PLAY, iCode=129 state=6001
104507.27 1 LsModuleTransition : 129, [TDX_PLAY]
104507.27 1 timer clear
104507.27 1 Play Module start
104507.27 1 state [ReminderPlayClinicName] Playing
104507.27 1 tts deleted previous C:\Program Files\VoiceGuide\data\tts_1_1.wav
104507.27 1 rv replace start: [$RV[CN]]
104507.27 1 rvns [PathSysVoice]{C:\Program Files\VoiceGuide\system\voice\}[PathApp]{C:\Program Files\VoiceGuide\}[PathDataVm]{C:\Program Files\VoiceGuide\data\}[PathVgSys]{C:\Program Files\VoiceGuide\system\}[DrName]{Lab}[Clinic]{270-759-9922}[CN]{Dr. Richard Blalock}[PatientName]{Darris Gene Pritchard}[ADT]{September 11 at 07:50 AM}[AppointmentDate]{1109}[AppointmentTime]{0750}[AllowTransfer]{Yes}[TransferPh
ne]{12707599922}[OutDial_RetriesLeft]{0}[$RV_STARTTIME]{9/8/2006 10:45:04 AM}[$RV_DEVICEID]{1}[$RV_CIDNAME]{}[PathApp]{C:\Program Files\VoiceGuide\}[$RV_CALLEDNUMBER]{12703822368}[OutDial_Result]{Contacted_Human}[scriptEnd_Ti
e]{9/8/2006 10:45:04 AM}[scriptEnd_Goto_Script]{c:\Recall4u\Scripts\DemoDialing\ReminderCall.vgs}[scriptEnd_Goto_Module]{}[scriptStart_Time]{9/8/2006 10:45:04 AM}[scriptStart_CalledFrom_Module]{ReminderHangup}[scriptsPath]{c:\Recall4u\Scripts\DemoDialing\}
104507.28 1 rv replace end: [Dr. Richard Blalock]
104507.28 1 tts generate start[Dr. Richard Blalock]
104507.28 1 tts generate wait
104507.31 1 tts generate finish
104507.33 1 state [ReminderPlayClinicName] Playing (C:\Program Files\VoiceGuide\data\tts_1_1.wav)
104507.33 1 tw ConvertWav2Vox C:\Program Files\VoiceGuide\data\tts_1_1.wav
104507.34 1 tw wav->vox convert end 645875,C:\Program Files\VoiceGuide\data\tts_1_1.vox,1,0,,
104507.38 1 play start ok, lPlayId=645906
104509.31 1 tw PlayEnd 1 645906
104509.31 1 play end id=645906, (current ID)
104509.31 1 event EV_PLAY_FINISHED, iCode=8001 state=1100
104509.33 1 LsPlayMsg EV_PLAY_FINISHED,EV_PLAY_FINISHED
104509.33 1 path {EV_PLAY_FINISHED} not found
104509.33 1 timer set 10 EV_TIMEOUT_HANGUP
104509.33 1 timer set 0 EV_TIMEOUT_GOTOMODULE
104509.33 1 event EV_TIMEOUT_GOTOMODULE, iCode=9002 state=1101
104509.33 1 LsPlayMsgFinished EV_TIMEOUT_GOTOMODULE,EV_TIMEOUT_GOTOMODULE
104509.33 1 path {EV_TIMEOUT_GOTOMODULE} not found
104509.34 1 next module is [ReminderPlayPatientName] (idx=29)
104509.34 1 fn RunModule start [Play,[ReminderPlayPatientName],29,,]
104509.34 1 tw DialogicEvent 129,TDX_PLAY,645906,0,0,,,
104509.34 1 event TDX_PLAY, iCode=129 state=6001
104509.34 1 LsModuleTransition : 129, [TDX_PLAY]
104509.34 1 timer clear
104509.36 1 Play Module start
104509.36 1 state [ReminderPlayPatientName] Playing
104509.36 1 tts deleted previous C:\Program Files\VoiceGuide\data\tts_1_2.wav
104509.36 1 rv replace start: [for $RV[PatientName]]
104509.36 1 rvns [PathSysVoice]{C:\Program Files\VoiceGuide\system\voice\}[PathApp]{C:\Program Files\VoiceGuide\}[PathDataVm]{C:\Program Files\VoiceGuide\data\}[PathVgSys]{C:\Program Files\VoiceGuide\system\}[DrName]{Lab}[Clinic]{270-759-9922}[CN]{Dr. Richard Blalock}[PatientName]{Darris Gene Pritchard}[ADT]{September 11 at 07:50 AM}[AppointmentDate]{1109}[AppointmentTime]{0750}[AllowTransfer]{Yes}[TransferPh
104509.38 1 rv replace end: [for Darris Gene Pritchard]
104509.38 1 tts generate start[for Darris Gene Pritchard]
104509.38 1 tts generate wait
104509.63 1 tts generate finish
104509.63 1 state [ReminderPlayPatientName] Playing (C:\Program Files\VoiceGuide\data\tts_1_2.wav)
104509.63 1 tw ConvertWav2Vox C:\Program Files\VoiceGuide\data\tts_1_2.wav
104509.66 1 tw wav->vox convert end 648171,C:\Program Files\VoiceGuide\data\tts_1_2.vox,1,0,,
104509.70 1 play start ok, lPlayId=648218
104511.72 1 tw PlayEnd 1 648218
104511.72 1 play end id=648218, (current ID)
104511.72 1 event EV_PLAY_FINISHED, iCode=8001 state=1100
104511.72 1 LsPlayMsg EV_PLAY_FINISHED,EV_PLAY_FINISHED
104511.72 1 path {EV_PLAY_FINISHED} not found
104511.72 1 timer set 10 EV_TIMEOUT_HANGUP
104511.73 1 timer set 0 EV_TIMEOUT_GOTOMODULE
104511.73 1 event EV_TIMEOUT_GOTOMODULE, iCode=9002 state=1101
104511.73 1 LsPlayMsgFinished EV_TIMEOUT_GOTOMODULE,EV_TIMEOUT_GOTOMODULE
104511.73 1 path {EV_TIMEOUT_GOTOMODULE} not found
104511.73 1 next module is [ReminderAppointmentDateTime2] (idx=41)
104511.73 1 fn RunModule start [Play,[ReminderAppointmentDateTime2],41,,]
104511.75 1 tw DialogicEvent 129,TDX_PLAY,648218,0,0,,,
104511.75 1 event TDX_PLAY, iCode=129 state=6001
104511.75 1 LsModuleTransition : 129, [TDX_PLAY]
104511.75 1 timer clear
104511.75 1 Play Module start
104511.75 1 state [ReminderAppointmentDateTime2] Playing
104511.77 1 tts deleted previous C:\Program Files\VoiceGuide\data\tts_1_3.wav
104511.77 1 rv replace start: [$RV[ADT]]
104511.77 1 rvns [PathSysVoice]{C:\Program Files\VoiceGuide\system\voice\}[PathApp]{C:\Program Files\VoiceGuide\}[PathDataVm]{C:\Program Files\VoiceGuide\data\}[PathVgSys]{C:\Program Files\VoiceGuide\system\}[DrName]{Lab}[Clinic]{270-759-9922}[CN]{Dr. Richard Blalock}[PatientName]{Darris Gene Pritchard}[ADT]{September 11 at 07:50 AM}[AppointmentDate]{1109}[AppointmentTime]{0750}[AllowTransfer]{Yes}[TransferPh
104511.77 1 rv replace end: [september 11 at 07:50 AM]
104511.77 1 tts generate start[september 11 at 07:50 AM]
104511.78 1 tts generate wait
104511.88 1 tts generate finish
104511.88 1 state [ReminderAppointmentDateTime2] Playing (C:\Recall4U\Scripts\DemoDialing\OfYourAppointment.wav, C:\Program Files\VoiceGuide\data\tts_1_3.wav)
104511.89 1 tw ConvertWav2Vox C:\Recall4U\Scripts\DemoDialing\OfYourAppointment.wav,C:\Program Files\VoiceGuide\data\tts_1_3.wav
104511.91 1 tw wav->vox convert end 650437,C:\Recall4U\Scripts\DemoDialing\OfYourAppointment.vox,C:\Program Files\VoiceGuide\data\tts_1_3.vox,1,0,,
104511.94 1 play start ok, lPlayId=650453
104516.95 1 tw PlayEnd 1 650453
104516.95 1 play end id=650453, (current ID)
104516.97 1 event EV_PLAY_FINISHED, iCode=8001 state=1100
104516.97 1 LsPlayMsg EV_PLAY_FINISHED,EV_PLAY_FINISHED
104516.97 1 path {EV_PLAY_FINISHED} not found
104516.97 1 timer set 10 EV_TIMEOUT_HANGUP
104516.97 1 timer set 0 EV_TIMEOUT_GOTOMODULE
104516.97 1 event EV_TIMEOUT_GOTOMODULE, iCode=9002 state=1101
104516.97 1 LsPlayMsgFinished EV_TIMEOUT_GOTOMODULE,EV_TIMEOUT_GOTOMODULE
104516.98 1 path {EV_TIMEOUT_GOTOMODULE} not found
104516.98 1 next module is [ReminderDrName] (idx=30)
104516.98 1 fn RunModule start [Play,[ReminderDrName],30,,]
104516.98 1 timer clear
104516.98 1 Play Module start
104516.98 1 state [ReminderDrName] Playing
104517.00 1 tts deleted previous C:\Program Files\VoiceGuide\data\tts_1_4.wav
104517.00 1 tw DialogicEvent 129,TDX_PLAY,650453,0,0,,,
104517.00 1 event TDX_PLAY, iCode=129 state=1100
104517.00 1 LsPlayMsg EV_UNKNOWN_129,TDX_PLAY
104517.00 1 path {TDX_PLAY} not found
104517.00 1 rv replace start: [with $RV[DrName]]
104517.00 1 rvns [PathSysVoice]{C:\Program Files\VoiceGuide\system\voice\}[PathApp]{C:\Program Files\VoiceGuide\}[PathDataVm]{C:\Program Files\VoiceGuide\data\}[PathVgSys]{C:\Program Files\VoiceGuide\system\}[DrName]{Lab}[Clinic]{270-759-9922}[CN]{Dr. Richard Blalock}[PatientName]{Darris Gene Pritchard}[ADT]{September 11 at 07:50 AM}[AppointmentDate]{1109}[AppointmentTime]{0750}[AllowTransfer]{Yes}[TransferPh
104517.02 1 rv replace end: [with Lab]
104517.02 1 tts generate start[with Lab]
104517.02 1 tts generate wait
104517.03 1 tts generate finish
104517.03 1 state [ReminderDrName] Playing (C:\Program Files\VoiceGuide\data\tts_1_4.wav)
104517.03 1 tw ConvertWav2Vox C:\Program Files\VoiceGuide\data\tts_1_4.wav
104517.05 1 tw wav->vox convert end 655578,C:\Program Files\VoiceGuide\data\tts_1_4.vox,1,0,,
104517.08 1 play start ok, lPlayId=655593
104518.19 1 tw PlayEnd 1 655593
104518.19 1 play end id=655593, (current ID)
104518.19 1 event EV_PLAY_FINISHED, iCode=8001 state=1100
104518.19 1 LsPlayMsg EV_PLAY_FINISHED,EV_PLAY_FINISHED
104518.19 1 path {EV_PLAY_FINISHED} not found
104518.19 1 timer set 10 EV_TIMEOUT_HANGUP
104518.20 1 timer set 0 EV_TIMEOUT_GOTOMODULE
104518.20 1 event EV_TIMEOUT_GOTOMODULE, iCode=9002 state=1101
104518.20 1 LsPlayMsgFinished EV_TIMEOUT_GOTOMODULE,EV_TIMEOUT_GOTOMODULE
104518.20 1 path {EV_TIMEOUT_GOTOMODULE} not found
104518.20 1 next module is [ReminderOptions] (idx=31)
104518.20 1 fn RunModule start [Play,[ReminderOptions],31,,]
104518.20 1 timer clear
104518.22 1 Play Module start
104518.22 1 state [ReminderOptions] Playing
104518.22 1 state [ReminderOptions] Playing (C:\recall4u\scripts\demodialing\ReminderConfirm.wav)
104518.22 1 tw ConvertWav2Vox C:\recall4u\scripts\demodialing\ReminderConfirm.wav
104518.22 1 tw DialogicEvent 129,TDX_PLAY,655593,0,0,,,
104518.22 1 event TDX_PLAY, iCode=129 state=1100
104518.23 1 LsPlayMsg EV_UNKNOWN_129,TDX_PLAY
104518.23 1 path {TDX_PLAY} not found
104518.23 1 tw wav->vox convert end 656765,C:\recall4u\scripts\demodialing\ReminderConfirm.vox,1,0,,
104518.27 1 play start ok, lPlayId=656781
104528.56 1 tw PlayEnd 1 656781
104528.56 1 play end id=656781, (current ID)
104528.56 1 event EV_PLAY_FINISHED, iCode=8001 state=1100
104528.56 1 LsPlayMsg EV_PLAY_FINISHED,EV_PLAY_FINISHED
104528.58 1 path {EV_PLAY_FINISHED} not found
104528.58 1 timer set 5 EV_TIMEOUT_REPLAYMSG
104528.58 1 tw DialogicEvent 129,TDX_PLAY,656781,0,0,,,
104528.58 1 event TDX_PLAY, iCode=129 state=1101
104528.58 1 LsPlayMsgFinished EV_UNKNOWN_129,TDX_PLAY
104528.58 1 path {TDX_PLAY} not found
104533.98 1 timer fired EV_TIMEOUT_REPLAYMSG
104533.98 1 event EV_TIMEOUT_REPLAYMSG, iCode=9005 state=1101
104533.98 1 LsPlayMsgFinished EV_TIMEOUT_REPLAYMSG,EV_TIMEOUT_REPLAYMSG
104533.98 1 path {EV_TIMEOUT_REPLAYMSG} not found
104533.98 1 state [ReminderOptions] Playing (C:\recall4u\scripts\demodialing\ReminderConfirm.wav)
104533.98 1 tw ConvertWav2Vox C:\recall4u\scripts\demodialing\ReminderConfirm.wav
104534.03 1 tw wav->vox convert end 672531,C:\recall4u\scripts\demodialing\ReminderConfirm.vox,1,0,,
104534.06 1 play start ok, lPlayId=672578
104544.36 1 tw PlayEnd 1 672578
104544.36 1 play end id=672578, (current ID)
104544.36 1 event EV_PLAY_FINISHED, iCode=8001 state=1100
104544.36 1 LsPlayMsg EV_PLAY_FINISHED,EV_PLAY_FINISHED
104544.36 1 path {EV_PLAY_FINISHED} not found
104544.36 1 timer set 10 EV_TIMEOUT_HANGUP
104544.38 1 timer set 5 EV_TIMEOUT_GOTOMODULE
104544.38 1 tw DialogicEvent 129,TDX_PLAY,672578,0,0,,,
104544.38 1 event TDX_PLAY, iCode=129 state=1101
104544.38 1 LsPlayMsgFinished EV_UNKNOWN_129,TDX_PLAY
104544.38 1 path {TDX_PLAY} not found
104548.83 1 tw DialogicEvent 134,TDX_CST,8650,0,0,DE_LCOF,,
104548.83 1 event DE_LCOF, iCode=134 state=1101
104548.83 1 LsPlayMsgFinished EV_UNKNOWN_134,DE_LCOF
104548.84 1 path {DE_LCOF} not found
104548.84 1 HangupCall start (Loop Current Off (non-xfer vgm))
104548.84 1 rv add [Hangup Time]{9/8/2006 10:45:48 AM}
104548.84 1 state Hanging up call... [Loop Current Off (non-xfer vgm)]
104548.84 1 HangupCall_Common hCall=643046
104548.86 1 rec RecSoundStop ok
104548.86 1 play PlayStop ok
104548.86 1 timer set 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP
104548.86 1 fnHangupCall end
104548.91 1 tw DialogicEvent 135,TDX_SETHOOK,0,0,0,DX_ONHOOK,,
104548.91 1 event TDX_SETHOOK, iCode=135 state=900
104548.91 1 LsAwaitingCalls EV_UNKNOWN_135
104548.91 1 event callstate IDLE 1 1,0,0
104548.92 1 WorkingMode@Idle=
104548.92 1 set LineState().hCall = 0 LineEvCallState-LINECALLSTATE_IDLE
104548.92 1 timer clear
104548.92 1 rec RecSoundStop ok
104548.92 1 play PlayStop ok
104548.94 1 rv add [CallEndTime]{9/8/2006 10:45:48 AM}
104548.94 1 timer set 1 EV_TIMEOUT_TIMETOREINITLINE
104549.95 1 timer fired EV_TIMEOUT_TIMETOREINITLINE
104549.95 1 event EV_TIMEOUT_TIMETOREINITLINE, iCode=9008 state=900
104549.95 1 init atidle reinit : start
104549.95 1 init atidle reinit iConferenceOtherLegLid=-1
104549.95 1 init atidle reinit : reset all LineState variables
104549.95 1 timer set 2 EV_TIMEOUT_AFTERIDLE_ALLOWOUT
104549.95 1 state Waiting for a call...
104552.16 1 timer fired EV_TIMEOUT_AFTERIDLE_ALLOWOUT
104552.16 1 event EV_TIMEOUT_AFTERIDLE_ALLOWOUT, iCode=9013 state=900
104552.16 1 setting iDialoutReadyToDialout=1
104552.78 1 dial [56,12702470781,609081031,800,2130,[Mo][Tu][We][Th][Fr],[,dxxxB1C1,],1,,c:\Recall4u\Scripts\DemoDialing\ReminderCall.vgs,c:\Recall4u\Scripts\DemoDialing\ReminderAM.vgs,[DrName]{Richard E Blalock},[Clinic]{270-759-9922},[CN]{Dr. Richard Blalock},[PatientName]{Sandra Edwards},[ADT]{September 11 at 11:00 AM},[AppointmentDate]{1109},[AppointmentTime]{1100},[AllowTransfer]{Yes},[Transf
rPhone]{12707599922},50,0,1,c:\Recall4u\Scripts\DemoDialing\ReminderNotConnected.vbs,none] (search started at 104552.78)
104552.78 1 dial DialOnLine start tel[12702470781] ann[] vgs[c:\Recall4u\Scripts\DemoDialing\ReminderCall.vgs] am[c:\Recall4u\Scripts\DemoDialing\ReminderAM.vgs] rv[[DrName]{Richard E Blalock},[Clinic]{270-759-9922},[CN]{Dr. Richard Blalock},[PatientName]{Sandra Edwards},[ADT]{September 11 at 11:00 AM},[AppointmentDate]{1109},[AppointmentTime]{1100},[AllowTransfer]{Yes},[Transf
rPhone]{12707599922}] cid[]
104552.78 1 rv clear all
104552.78 1 rv add [DrName]{Richard E Blalock}
104552.80 1 rv add [Clinic]{270-759-9922}
104552.80 1 rv add [CN]{Dr. Richard Blalock}
104552.80 1 rv add [PatientName]{Sandra Edwards}
104552.80 1 rv add [ADT]{September 11 at 11:00 AM}
104552.80 1 rv add [AppointmentDate]{1109}
104552.80 1 rv add [AppointmentTime]{1100}
104552.81 1 rv add [AllowTransfer]{Yes}
104552.81 1 rv add [TransferPhone]{12707599922}
104552.81 1 rv add [OutDial_RetriesLeft]{0}
104552.81 1 dial making call tel[12702470781] ann[] vgs[c:\Recall4u\Scripts\DemoDialing\ReminderCall.vgs] am[c:\Recall4u\Scripts\DemoDialing\ReminderAM.vgs] OnHangup[] rv[[DrName]{Richard E Blalock},[Clinic]{270-759-9922},[CN]{Dr. Richard Blalock},[PatientName]{Sandra Edwards},[ADT]{September 11 at 11:00 AM},[AppointmentDate]{1109},[AppointmentTime]{1100},[AllowTransfer]{Yes},[Transf
rPhone]{12707599922}[OutDial_RetriesLeft]{0}]
104552.81 1 script interpretor: VgMulti v6.0.3149
104552.81 1 state Dialing 12702470781
104552.84 1 lineMakeCall=>[]
104552.86 1 timer set 50 EV_TIMEOUT_MAKECALL_NORESPONSE
104553.39 1 tw DialogicEvent 135,TDX_SETHOOK,0,0,0,DX_OFFHOOK,CALL_OUTBOUND,
104553.39 1 event TDX_SETHOOK, iCode=135 state=5200
104553.39 1 LsWaitAfterDialingOut : 135,TDX_SETHOOK,0,0,0,DX_OFFHOOK,CALL_OUTBOUND,
104553.39 1 tw DialogicEvent 135,RLS_LCSENSE,0,0,0,DX_OFFHOOK,CALL_OUTBOUND,
104553.41 1 event RLS_LCSENSE, iCode=135 state=5200
104553.41 1 LsWaitAfterDialingOut : 135,RLS_LCSENSE,0,0,0,DX_OFFHOOK,CALL_OUTBOUND,
104553.41 1 state Line not plugged in (RLS_LCSENSE)
104553.41 1 DialoutProcessFailedDial start sCalledFrom=[LsWaitAfterDialingOut-RLS_LCSENSE] RetriesLeft=0
104553.41 0 dial callque delete id=56 (MSAccess)
104553.41 1 rvns add [OutDial_Result]{Uncontactable_Error}
104553.41 1 timer clear
104553.42 1 rv replace start (strlen>500)
104553.42 1 rvns [PathSysVoice]{C:\Program Files\VoiceGuide\system\voice\}[PathApp]{C:\Program Files\VoiceGuide\}[PathDataVm]{C:\Program Files\VoiceGuide\data\}[PathVgSys]{C:\Program Files\VoiceGuide\system\}[DrName]{Richard E Blalock}[Clinic]{270-759-9922}[CN]{Dr. Richard Blalock}[PatientName]{Sandra Edwards}[ADT]{September 11 at 11:00 AM}[AppointmentDate]{1109}[AppointmentTime]{1100}[AllowTransfer]{Yes}[TransferPh
ne]{12707599922}[OutDial_RetriesLeft]{0}[OutDial_Result]{Uncontactable_Error}
104553.42 1 vbs replaced rv and ran shell[wscript "C:\Program Files\VoiceGuide\data\vbs_1_OnNotConnected_060908104553.vbs" //I //T:3600]
104553.47 1 VBScript started [wscript "C:\Program Files\VoiceGuide\data\vbs_1_OnNotConnected_060908104553.vbs" //I //T:3600]
104553.48 1 OnNotConnected run ok []
104553.48 1 dial no escalation info
104553.48 1 HangupCall start (DX_OFFHOOK in LsWaitAfterDialingOut (RLS_LCSENSE))
104553.48 1 rv add [Hangup Time]{9/8/2006 10:45:53 AM}
104553.48 1 state Hanging up call... [DX_OFFHOOK in LsWaitAfterDialingOut (RLS_LCSENSE)]
104553.48 1 HangupCall_Common hCall=0
104553.50 1 rec RecSoundStop ok
104553.50 1 play PlayStop ok
104553.50 1 timer set 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP
104553.50 1 HangupCall : lCallHandle& = 0 - lets close and open line
104553.52 1 state Waiting for a call...
104553.52 1 fnHangupCall end
104553.52 1 tw DialogicEvent 134,TDX_CST,462,0,0,DE_LCON,,
104553.52 1 event TDX_CST, iCode=134 state=900
104553.52 1 LsAwaitingCalls EV_UNKNOWN_134
104555.59 1 timer fired EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP
104555.59 1 event EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP, iCode=9101 state=900
104555.59 1 state Hanging up call...(2)
104555.59 1 HangupCall_Common hCall=0
104555.59 1 rec RecSoundStop ok
104555.61 1 play PlayStop ok
104555.61 1 HangupCall : lCallHandle& = 0 - lets close and open line
104555.61 1 state Waiting for a call...
104555.63 1 fnHangupCall end
104555.63 1 LsAwaitingCalls EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP
104555.63 1 tw DialogicEvent 137,TDX_ERROR,0,0,0,,,
104555.63 1 event TDX_ERROR, iCode=137 state=900
104555.63 1 LsAwaitingCalls EV_UNKNOWN_137
104555.64 1 event TDX_ERROR, iCode=137 state=900
104555.64 1 LsAwaitingCalls EV_UNKNOWN_137
It looks like the Dialogic card has not detected any loop current on the line after 'picking up' the line.
We'll see if we can reproduce the problem. Should have something available in a day or so.
When posting traces of more then about 20 lines or scripts please .ZIP them up and post them as attachments.
v6.0.3157 now available for download does not check for LoopCurrent presence by default.
This option needs to be turned on in VG.INI file's [VGDialer] section, by setting LoopCurrentReqBeforeDialing=1
Turning that option on would make the software check for loop current after lifting the handset, and if no loop current is detected the outbound call would fail.
In v6.0.3157 test for loop current is made (if LoopCurrentReqBeforeDialing=1) immediately after picking up the line. In future versions we will introduce a setting which will let user select how long VoiceGuide will wait for loop current to appear after picking up the line.
