Two Queries
Are the following External USB boards suitable for voiceguide IVM, Cahta boards ; telTELCTAUSB2, TELCTAUSB4?
Also on one line with a three or four way rj25 splitter with several devices fitted which device get incoming connection priority?
Many thanks
Never tested these cards ourselves. We recommend using the industry standard Dialogic cards.
The one which is set to answer in the least number of rings... All the devices connected in parallel will hear the ringing at the same time.
