Guest fsoudbakhsh Report post Posted 09/13/2006 05:17 AM hello, the job of bellow script is to insert data in the webdatabase and it works find. but VB module is keep getting the fail path. The error message I get in log file is: No information returned from program to VG (no VGRUNRESULT_5.TXT or SHLRESLT.TXT) please see log file in doc file attached. I can not find out why the fail path is keep taking. would you please advice what should do? Thanks Farzad Set IE = CreateObject("InternetExplorer.Application") With IE .RegisterAsDropTarget = False .Visible = False .Silent = True .Navigate("http://farzadinc.com/default.asp?pcuser=root&pcpass=passme") While .Busy WScript.Sleep 500 Wend page = "http://farzadinc.com/command.asp?sqls=insert into 2 values ('Germany', '77', '5533', 77 )" .Navigate(page) While .Busy WScript.Sleep 500 Wend With .Document.Body readWwwHtml = .InnerHTML readWwwText = .InnerText End With End With IE.Quit Set IE = Nothing error.doc Share this post Link to post
SupportTeam Report post Posted 09/13/2006 05:38 AM If the script does not return any information to VoiceGuide then the fail path will be taken. From http://www.voiceguide.com/vghelp/html/modVbs.htm : Wait until VBScript completes option [...] A "Success" or Result Variable list must be returned to VoiceGuide (either though a Run_ResultReturn COM function or a Result File) in order for it to go down the Success path. If no result is returned then the "Fail" path is taken after the VBScript completes. The VBScript you're using does not return any response to VoiceGuide so the system behaves as expected... Share this post Link to post
