Web Dataaccess
Hello,
Bellow VB script job is to select Pin number from the web database (Access file) and pass it to result variable call SQLS.
I don't received any error when I run this scripts in VG but VG doesn't get any result variable from this script.
I am not sure which one is not working correctly? VG or my VB script!
I do have other VB scripts that does update, insert, and delete data from and into the web data base, and none of them has any problem.
If you can give me hint which one (Script or VG) has the problem and where the problem is I would be appreciated.
Farzad
DIM VerfCNum, sqls
Set IE = CreateObject("InternetExplorer.Application")
With IE
.RegisterAsDropTarget = False
.Visible = False
.Silent = True
.Navigate("http://farzadinc.com/default.asp?pcuser=root&pcpass=passme")
While .Busy
WScript.Sleep 500
Wend
.Navigate("http://farzadinc.com/command.asp?sqls=select CNUM from CC where Deposit=50 and Balance = 50 and CurrancyType = 1")
While .Busy
WScript.Sleep 500
Wend
With .Document.Body
readWwwHtml = .InnerHTML
readWwwText = .InnerText
End With
End With
IE.Quit
Set IE = Nothing
set VG = CreateObject("VoiceGuide.CommandLink")
vg.Run_ResultReturn $RV_LINEID, "[VerfCNum]{" & sqls & "}"
set VG = Nothing
The script is returning value of variable sqls in this command:
but sqls is not set anywhere... so $RV[VerfCNum] would be holding a blank value after the script returns..
maybe the script should be returning the readWwwText variable, like this:
vg.Run_ResultReturn $RV_LINEID, "[VerfCNum]{" & readWwwText & "}"
That way $RV[VerfCNum] would be holding the value of variable readWwwText...
