Guest fsoudbakhsh Report post Posted 09/20/2006 12:22 AM Hello, Bellow VB script job is to select Pin number from the web database (Access file) and pass it to result variable call SQLS. I don't received any error when I run this scripts in VG but VG doesn't get any result variable from this script. I am not sure which one is not working correctly? VG or my VB script! I do have other VB scripts that does update, insert, and delete data from and into the web data base, and none of them has any problem. If you can give me hint which one (Script or VG) has the problem and where the problem is I would be appreciated. Thanks Farzad DIM VerfCNum, sqls Set IE = CreateObject("InternetExplorer.Application") With IE .RegisterAsDropTarget = False .Visible = False .Silent = True .Navigate("http://farzadinc.com/default.asp?pcuser=root&pcpass=passme") While .Busy WScript.Sleep 500 Wend .Navigate("http://farzadinc.com/command.asp?sqls=select CNUM from CC where Deposit=50 and Balance = 50 and CurrancyType = 1") While .Busy WScript.Sleep 500 Wend With .Document.Body readWwwHtml = .InnerHTML readWwwText = .InnerText End With End With IE.Quit Set IE = Nothing set VG = CreateObject("VoiceGuide.CommandLink") vg.Run_ResultReturn $RV_LINEID, "[VerfCNum]{" & sqls & "}" set VG = Nothing Share this post Link to post
SupportTeam Report post Posted 09/20/2006 01:14 AM The script is returning value of variable sqls in this command: vg.Run_ResultReturn $RV_LINEID, "[VerfCNum]{" & sqls & "}" but sqls is not set anywhere... so $RV[VerfCNum] would be holding a blank value after the script returns.. maybe the script should be returning the readWwwText variable, like this: vg.Run_ResultReturn $RV_LINEID, "[VerfCNum]{" & readWwwText & "}" That way $RV[VerfCNum] would be holding the value of variable readWwwText... Share this post Link to post
