Can't Connect To Access Database - 3151:ODBC error
Hi!
I finally found a voice modem that would allow me to test VoiceGuide...the AOpen FM-56 PX. So far, it's working great using a Skutch AS-4A line simulator.
I'm working on a script that will query an Access database, but I'm having trouble connecting to it (see the attached trace log for the message).
This is what I have in the script module that is doing the database query:
Database or ODBC Data Source: D:\Data\Potential Businesses\Video Rental\IVR rental\VideoVision files\data\Store1.mdb
Connect string: PWD=052884 [note: the database has a password on it]
SELECT Title FROM Videos limit 1 [to only pull in a sample record for testing]
The query fails because it can't connect to the database.
Any ideas what I might be doing wrong? Thanks!
0921vgm.txt
A correction to the above...my SELECT statement reads:
SELECT Title FROM Videos WHERE Ref='1'
...since Access doesn't seem to have a LIMIT command like MySQL.
I get the same problem (unable to connect)...
Can the module connect when the database is not password protected?
The Help file indicates that the connect string which just supplies the password should begin with a ";", like this:
;PWD=mypassword
