dsb777 Report post Posted 09/24/2006 03:56 AM hi, I cant get the TTS to work possibly because im using the way2Call usb modem... So, I have the caller able to query an access database and i want to return a phone number... I have the say number module set to digits but it will say the word "minus" between area code etc... Is there a way to let it know its a phone number? I guess i could just put a blank wav in place of the system "minus.wav" file but wanted to check with you first... Share this post Link to post
dsb777 Report post Posted 09/24/2006 04:15 AM where woudl i find teh fiel so that i can edit teh voices used for characters? like, if there is a 5, VG plays the five.wav but i want to add an ampersign (&) and make it play an "and.wav" wav. Share this post Link to post
SupportTeam Report post Posted 09/24/2006 09:18 AM Quote I guess i could just put a blank wav in place of the system "minus.wav" file but wanted to check with you first... Yes, that would work. A better approach would be to edit the lib_num2wav.vbs file and add to it a new function which speaks the number and does not say the "minus" word when it encounters the minus sign. You would then be able to use this new function from within the script. Have a look at: http://www.voiceguide.com/vghelp/html/SoundFiles.htm and at: http://www.voiceguide.com/vghelp/html/Multi-language.htm Quote i want to add an ampersign (&) and make it play an "and.wav" wav. Again, this would be best done by adding a new function to lib_num2wav.vbs Share this post Link to post
dsb777 Report post Posted 09/25/2006 04:11 AM ok great I think that is what i am looking for.... Can you tell me how to add an additional "IF Statement"??? I just added another IF but it caused an error.. LOL im not a great programmer i guess. lolol see below... how can i have two IFs ???? thanks If sDigit = "-" Then sWav = "minus.wav" If sDigit = "+" Then sWav = "and.wav" Else sWav = sDigit & ".wav" end If Share this post Link to post
dsb777 Report post Posted 09/25/2006 04:44 AM hey again. : ) I still need the above question answered (about having 2 IF statements), but here is a second question on the same topic.... Can I set the file up to ignore certain characters? example... When it comes across a space, it will play the file "errorPlayingFile.wav"... Plus I was thinking maybe i would just have it ignore the minus sign... ok well thanks. : ) Share this post Link to post
SupportTeam Report post Posted 09/25/2006 05:28 AM Quote how can i have two IFs ???? Try this: If sDigit = "-" Then sWav = "minus.wav" Else If sDigit = "&" Then sWav = "and.wav" Else sWav = sDigit & ".wav" end If (we also replaced "+" with a "&" above). A version which ignores characters other then 0-9,&,- would be: If sDigit = "-" Then sWav = "minus.wav" Else If sDigit = "&" Then sWav = "and.wav" Else If sDigit >= "0" and sDigit < "9" sWav = sDigit & ".wav" end If This may be a more appropriate version for you to use if the input may have unexpected characters in it. It will ensure that only the expected characters get played. We will probably modify the default lib_num2wav.vbsfunctions to have the If sDigit >= "0" and sDigit < "9" test in there - we can see that not having that test there may lead to problems. Share this post Link to post
dsb777 Report post Posted 09/26/2006 05:56 AM damn.. not working... im getting script errors... one refers to script:\temp\vbs_6_sayNumber.vbs???? i get expected "then"... i put a then in there, & get "unexpected next" can you tell me the whole function code: heres what i have as my function.. can u fix it for me? : ) Function Digits(byval arg1) 'returns a list of comma delimited wav files, 'with each wav file corresponding to a character 'in the supplied input string. sDigits=Trim(arg1) For i=1 To Len(sDigits) sDigit = Mid(sDigits, i, 1) If sDigit = "-" Then sWav = "silence.wav" Else If sDigit = "&" Then sWav = "and.wav" Else If sDigit >= "0" and sDigit < "9" then sWav = sDigit & ".wav" end If If sOut = "" Then sOut = sWav else sOut = sOut & "," & sWav End if Next Digits = sOut End Function Share this post Link to post
SupportTeam Report post Posted 09/26/2006 06:16 AM The script should have been tested before it was posted... here is a version I tested: Function Digits(byval arg1) 'returns a list of comma delimited wav files, 'with each wav file corresponding to a character 'in the supplied input string. sDigits=Trim(arg1) For i=1 To Len(sDigits) sDigit = Mid(sDigits, i, 1) If sDigit = "-" Then sWav = "silence.wav" ElseIf sDigit = "&" Then sWav = "and.wav" ElseIf sDigit >= "0" and sDigit < "9" then sWav = sDigit & ".wav" else sWav = "" end If if sWav <> "" Then If sOut = "" Then sOut = sWav else sOut = sOut & "," & sWav End if End if Next Digits = sOut End Function Notice how "Else If" is now "ElseIf" (no space) and there is an extra few lines here and there... Share this post Link to post
dsb777 Report post Posted 09/26/2006 06:55 AM Yes thanks! This works perfectly! : ) Im happy.. now i can go to sleep. LOL Thanks alot! Share this post Link to post
