Retrieving Data From Web Database
Hello,
would you please modify example below in your help page so that it retrieves data from the web database (Access database uploaded to host)?
Your help will benefit a lot of people who have problem retrieving data with VoiceGuide from a web database.
Example 13:
Retrieving data from an MS SQL Server Database:
set cn = CreateObject("ADODB.Connection")
set rs = CreateObject("ADODB.Recordset")
cn.Open "Provider=SQLOLEDB;Server=DBSERVER1;UID=user;PWD=user;Database=Ads" 'MSSQL authentication
if cn.State <> 1 then
vg.Admin_TraceLogAdd iLineId, 5, "login LeadingAd connection to database could not be made"
vg.Run_ResultReturn iLineId, "fail"
WScript.Quit
end if
set rs.ActiveConnection = cn
sSQL = "SELECT TOP 1 AdID, Filename, PlayCount, LastPlayTime FROM AdList WHERE PlayCount < PlayCountMax AND Active <> 0 ORDER BY LastPlayTime"
rs.Open sSQL, cn, 3
if rs.RecordCount <= 0 then
rs.Close
vg.Admin_TraceLogAdd iLineId, 5, "no records retrieved"
else
iAdID = rs.Fields("AdID").Value
sFilename = rs.Fields("Filename").Value
iPlayCount = rs.Fields("PlayCount").Value
dateLastPlayTime = rs.Fields("LastPlayTime").Value
rs.Close
sSQL = "UPDATE AdList SET PlayCount=" & iPlayCount & ", LastPlayTime=" & strDateTimeNow & " WHERE AdID=" & iAdID
vg.Admin_TraceLogAdd iLineId, 5, "sql=[" & sSQL & "]"
cn.Execute sSQL
sSQL = "INSERT INTO PlayLog (AdID, CallID, PlayDateTime, PlayedFrom) VALUES (" & iAdID & ", 0, " & strDateTimeNow & ", 'AnswerCall')"
vg.Admin_TraceLogAdd iLineId, 5, " sql=[" & sSQL & "]"
cn.Execute sSQL
end if
cn.Close
set rs = Nothing
set cn = Nothing
set vg = Nothing
WScript.Quit
What do you mean by "Web Database" ?
Are you referring to some web service which is used to retrieve data from a database? (There is an example for that in the Help file's entry on VBScript module).
No it is not a web services. It is my own database (Access database) that I have upload in my website and know I want to retrieve specific data from it.
The sample you have in help file is just to read the last record in database which has been sorted. I need to use select command and where clause to retriever the specific data I want.
Not sure how you could work with a database like that. You may want to speak to a Web Designer to see how you can retrieve information from such databases...
