Outgoing Call Hangs
I've upgraded to the latest version of VoiceGuide (6.0.3160) (WinXP & all the usual service packs) and I'm having problems with the Outdialer. Quite often throughout the day one (or several) of the outgoing lines will lock at OMG1 and the line(s) becomes unusable until I manually hang up the call. I have attached the log and the previous outgoing call on this line. The problem call starts at 180956.63. I was wondering if you could point me in the right direction?
Error.zip
The trace supplied only had minimal logging in it, and it does not show enough information to show what happened.
What was the trace level set to on this machine? (1 ?)
[Log]
VoiceGuide=10
NumberLoader=0
VoicemailManager=0
EmailSender=0
TapiWrapOcx=10
SapiWrapOcx=0
Then restart VG.
After you see the problem occur please post the traces. (include some other calls in the trace as well for comparison)
