Cepstral Voices
will the TTS engine from cepstral work with VG for dialogic,
I have install the trial verison but it does not play the wav files
Any ideas on how I can fix this.
It should work.
Did you select Cepstral as the default TTS in the Windows' Control Panel's "Speech" applet?
I selected the correct voice option, but inital test calls did not play the tts file after a system restart the promblem resolved itself.
I now need the programme to create wave file (export to audio file) I select the 11khz 8bit mono option but when VG plays it the file is the wrong format - slow & low speech.
Any ideas ?
OK.
VoiceGuide for Dialogic uses 8kHz PCM files. 11kHz files will sound 'slowed down'.
