Problem On Transfer Call
I have a PC with XP PRO SP2 and USB VOICE MODEM Smartlink.
I have a problem when i try to make a transfer call.
It's seem that a EV_TIMEOUT_HANGUP force the PBX to respond in 3 seconds.
It is possible to change this setting?
090619,64 0 timer set 0,4 EV_TIMEOUT_READYTOBEGINTRANSFER
090620,03 0 timer fired EV_TIMEOUT_READYTOBEGINTRANSFER
090620,03 0 ScriptEventCode 9012 iLineState=1900
090620,03 0 LsXferStart EV_TIMEOUT_READYTOBEGINTRANSFER
090620,03 0 timer set 20 EV_TIMEOUT_ANNOUNCED_TRANSFER_ATTEMPT_TOOK_TOO_LONG
090620,03 0 state [Centralino] Blind Transfer to ,108 (Generate)
090620,04 0 tapic lineGenerateDigits(66307 [!] 100) => ok
090620,15 0 generate LINEGENERATETERM_DONE
090620,17 0 timer set 1 EV_TAPI_GENERATE
090621,25 0 timer fired EV_TAPI_GENERATE
090621,25 0 ScriptEventCode 9602 iLineState=1900
090621,25 0 LsXferStart EV_TAPI_GENERATE
090621,25 0 timer set 1 EV_HOOKFLASHFINISHED
090622,34 0 timer fired EV_HOOKFLASHFINISHED
090622,34 0 ScriptEventCode 9200 iLineState=1905
090622,34 0 LsXferPlayVts EV_HOOKFLASHFINISHED
090622,34 0 tapic lineGenerateDigits(66307 [,108] 100) => ok
090623,01 0 generate LINEGENERATETERM_DONE
090623,03 0 timer set 1 EV_TAPI_GENERATE
090624,11 0 timer fired EV_TAPI_GENERATE
090624,11 0 ScriptEventCode 9602 iLineState=1905
090624,11 0 LsXferPlayVts EV_TAPI_GENERATE
090624,11 0 timer set 3 EV_TIMEOUT_HANGUP
090627,39 0 timer fired EV_TIMEOUT_HANGUP
090627,39 0 ScriptEventCode 9001 iLineState=1905
090627,39 0 LsXferPlayVts EV_TIMEOUT_HANGUP
090627,39 0 rv lg add [Hangup Time]{26/09/2006 9.06.27}
090627,39 0 state Hanging up call...
If you do not see the transfer working then it looks like the modem is not issuing a hookflash that is correct length for your PBX. There is no way to change the hookflash length of modems.
You should look at getting a Dialogic card.
