Zoltan Report post Posted 10/04/2006 08:33 AM In the new VG for Dialogic 3164 version the digits do not read correctly. It seems you made changes on September 26 in the Digits function and since then it is wrong I had to replace the lib_num2wav with a previous version. The previous version worked fine for me, why did you ruin it? Share this post Link to post
SupportTeam Report post Posted 10/04/2006 09:01 AM The new digits function was designed to not speak anything else but digits and "-" and "&" characters, whereas old digits functions was trying to speak every character regardless of what it was (digits, letters, etc). The version from 26th did however try to speak the "-" character as "silence.wav", and not as "minus.wav". Below is the correct version which speaks the "-" character as "minus.wav". '###### 'name : Digits 'info : Say the digits in the number 'arg1 : Digits to be spoken : '###### Function Digits(byval arg1) 'returns a list of comma delimited wav files, 'with each wav file corresponding to a character 'in the supplied input string. sDigits=Trim(arg1) For i=1 To Len(sDigits) sDigit = Mid(sDigits, i, 1) If sDigit = "-" Then sWav = "minus.wav" ElseIf sDigit = "&" Then sWav = "and.wav" ElseIf sDigit >= "0" and sDigit < "9" then sWav = sDigit & ".wav" else sWav = "" end If if sWav <> "" Then If sOut = "" Then sOut = sWav else sOut = sOut & "," & sWav End if End if Next Digits = sOut End Function Share this post Link to post
Zoltan Report post Posted 10/04/2006 05:16 PM I didn't have any special charachters in my numbers.They are just positive integers like 59 or 12345 etc. The say number module, digits function either skipped a digit or skipped a whole number. Share this post Link to post
SupportTeam Report post Posted 10/04/2006 08:36 PM digits function either skipped a digit or skipped a whole number. We have not encountered anything like that in our testing... We'd need to see a trace which demonstrates the problem. Enable logging by setting the log levels to 10 in VG.INI as per below: [Log] VoiceGuide=10 NumberLoader=0 VoicemailManager=0 EmailSender=0 TapiWrapOcx=10 SapiWrapOcx=0 Then restart VG and make a test call which demonstrates the problem. Debug Trace files will be created in VG's \log\ subdirectory. Please post the traces and the VoiceGuide script used. When posting traces/scripts please .ZIP them up and post them as attachments. Share this post Link to post
Zoltan Report post Posted 10/07/2006 08:13 AM I have found the bug in the lib_num2wav Digits function. It does not say 9 because in the the following line ElseIf sDigit >= "0" and sDigit < "9" then you missed the = sign in the sDigit <= 9 Share this post Link to post
SupportTeam Report post Posted 10/07/2006 08:38 AM Thanks for reporting the problem. Here is the updated version of lib_num2wav.vbs (attached to this post). The attached lib_num2wav.vbs should be placed in VoiceGuide's \System\vbs\ subdirectory, replacing existing version. The new lib_num2wav.vbs will be included in next VoiceGuide for Dialogic install update. lib_num2wav.zip Share this post Link to post
