frequency34 Report post Posted 10/10/2006 08:03 PM Hi, I need to implement call transfer.. Our office does not use a PBX, nor do we have the facility of 'extensions' by which by dialing the extension number an incoming call is transfered to the extension. So I am guessing I will have to use the Dial and Conference Method to do call transfer. I am using D/4 PCIUF card. I read somewhere that this card cannot be used to do call transfer. Is that true ?(if so then i am in big trouble since I already bought this card long back Anyway, how does dial and conference work? I have 2 phone lines plugged into the card. I will call on one, then voice guide will use the other line to dial any number? Like I can simply specify a 10 digit cell phone number (xxx)-xxx-xxxx ? Well when I use "Dialout and Conference Blind" I get the following message on the line which is supposed to make the outgoing call: Dialing (xxx)-xxx-xxxx for conference with dxxxB1C4 But after that nothing happens, I do not receive any calls on the number i have specified. How can I tell from the event trace log whether this is due to the card or is it something else... Here is the log.. 035554.63 4 event callstate OFFERING 4 2,0,0 035554.63 4 script interpretor: VgMulti v6.0.3157 035554.63 4 fired OFFERING event to listeners 035554.63 4 set LineState().hCall = 4 in LINECALLSTATE_OFFERING 035554.63 4 cid CallerID vars set (in 'offering' event) [,,] 035554.64 4 call AnswerTheCallIfAllowed from LINECALLSTATE_OFFERING 035554.64 4 rings=0, min rings before answer=0 (iCallerIdHasArrived=0) 035554.64 4 tw ring 1 035554.64 4 ring time since last ring event (sec): 0.00 035554.64 4 rings=1, min rings before answer=0 (iCallerIdHasArrived=0) 035554.64 4 should answer as number of rings reached 035554.64 4 rv clear all 035554.64 4 init LineState ResetAtStartOfNewCall. 035554.64 4 answering the call (,,,0) 035554.64 4 timer clear 035554.64 4 tw DialogicEvent 134,TDX_CST,0,0,0,DE_RINGS,ET_RON, 035554.64 4 event TDX_CST, iCode=134 state=6001 035554.64 4 LsModuleTransition : 134, [TDX_CST] 035555.28 4 tw DialogicEvent 135,TDX_SETHOOK,0,0,0,DX_OFFHOOK,CALL_INBOUND, 035555.28 4 event TDX_SETHOOK, iCode=135 state=6001 035555.28 4 LsModuleTransition : 135, [TDX_SETHOOK] 035555.28 4 event callstate CONNECTED 4 256,0,0 035555.28 4 LineEvCallState_Connected hDevice=4 params=256,0,0 035555.28 4 WorkingModes tapi= script= LineState().iState=6001 035556.28 4 Inband detection not enabled 035556.28 4 StartLoadedVgs at 10/10/2006 3:55:56 AM (VgMulti v6.0.3157) 035556.28 4 set LineState().iVgsIdx=3 035556.28 4 set sScriptToRunOnHangup=[] in StartLoadedVgs 035556.30 4 init StartLoadedVgs_InitLineState start 035556.30 4 rv add [$RV_STARTTIME]{10/10/2006 3:55:56 AM} 035556.30 4 rv add [$RV_DEVICEID]{4} 035556.30 4 rv add [$RV_CIDNAME]{} 035556.30 4 rvns add [PathApp]{C:\Program Files\VoiceGuide\} 035556.30 4 rvns add [scriptsPath]{C:\Program Files\VoiceGuide\Scripts\version 7\} 035556.30 4 rv add [$RV_CIDNUMBER]{} 035556.30 4 fn RunModule start [Play,[Play 1],16,,] 035556.30 4 tw DialogicEvent 134,TDX_CST,25721,0,0,DE_LCON,, 035556.30 4 event TDX_CST, iCode=134 state=6001 035556.30 4 LsModuleTransition : 134, [TDX_CST] 035556.32 4 timer clear 035556.32 4 Play Module start 035556.32 4 state [Play 1] Playing 035556.32 4 tts deleted previous C:\Program Files\VoiceGuide\data\tts_4_1.wav 035556.32 4 tts generate start[hello. transfering call..] 035556.32 4 tts generate wait 035556.35 4 tts generate finish 035556.35 4 state [Play 1] Playing (C:\Program Files\VoiceGuide\data\tts_4_1.wav) 035556.35 4 tw ConvertWav2Vox C:\Program Files\VoiceGuide\data\tts_4_1.wav 035556.36 4 tw wav->vox convert end 773687,C:\Program Files\VoiceGuide\data\tts_4_1.vox,1,0,, 035556.38 4 play start ok, lPlayId=773718 035559.14 4 tw PlayEnd 4 773718 035559.16 4 play end id=773718, (current ID) 035559.16 4 event EV_PLAY_FINISHED, iCode=8001 state=1100 035559.16 4 LsPlayMsg EV_PLAY_FINISHED,EV_PLAY_FINISHED 035559.16 4 path {EV_PLAY_FINISHED} not found 035559.16 4 timer set 10 EV_TIMEOUT_HANGUP 035559.16 4 timer set 0 EV_TIMEOUT_GOTOMODULE 035559.16 4 event EV_TIMEOUT_GOTOMODULE, iCode=9002 state=1101 035559.16 4 LsPlayMsgFinished EV_TIMEOUT_GOTOMODULE,EV_TIMEOUT_GOTOMODULE 035559.16 4 path {EV_TIMEOUT_GOTOMODULE} not found 035559.16 4 next module is [Transfer Call 33] (idx=17) 035559.16 4 fn RunModule start [Transfer Call,[Transfer Call 33],17,,] 035559.16 4 tw DialogicEvent 129,TDX_PLAY,773718,0,0,,, 035559.17 4 event TDX_PLAY, iCode=129 state=6001 035559.17 4 LsModuleTransition : 129, [TDX_PLAY] 035559.17 4 timer clear 035559.17 4 timer set 0.4 EV_TIMEOUT_READYTOBEGINTRANSFER 035559.58 4 timer fired EV_TIMEOUT_READYTOBEGINTRANSFER 035559.58 4 event EV_TIMEOUT_READYTOBEGINTRANSFER, iCode=9012 state=1901 035559.58 4 LsXfer_1_Start : 9012(EV_TIMEOUT_READYTOBEGINTRANSFER),EV_TIMEOUT_READYTOBEGINTRANSFER,0,0,0,,, 035559.58 4 path {EV_TIMEOUT_READYTOBEGINTRANSFER} not found 035559.58 4 timeout on transfer attempt set by VG.INI [PBX] AnnouncedTransfersMaxWaitTime (30 sec) 035559.58 4 timer set 30 EV_TIMEOUT_ANNOUNCED_TRANSFER_ATTEMPT_TOOK_TOO_LONG 035559.58 4 state [Transfer Call 33] Announced Dial and Connect to 13522262369 035559.58 dial search for free lines in LineID range [0-4] 035559.58 1 dial reserving: no list specified 035559.58 4 dial found free dev=1 (LineId=1) in XferDialAndConference 035559.58 4 no on-hold file specified to play 035559.60 1 state dialing 13522262369 (for conference with dxxxB1C4) iXferBridgeCallsWhen=0, sCallProgressOption=CONNECT_IMMEDIATELY (Immediately after dialing.) 035559.60 1 lineMakeCall(13522262369,CONNECT_IMMEDIATELY) (in XferDialAndConference) => 0 035559.60 1 call progress option selected: Immediately after dialing. 035559.60 4 announced DC transfer (33) 035600.14 1 tw DialogicEvent 135,TDX_SETHOOK,0,0,0,DX_OFFHOOK,CALL_OUTBOUND, 035600.14 1 event TDX_SETHOOK, iCode=135 state=1922 035600.14 1 LsXfer_6_dc_WaitOutcomeOutgoingCall_OutLeg : 135,[TDX_SETHOOK],0,0,0,DX_OFFHOOK,CALL_OUTBOUND, 035600.14 4 LsXfer_6_dc_WaitOutcomeOutgoingCall_InLeg : [TDX_SETHOOK], 135(EV_UNKNOWN_135),0,0,0,DX_OFFHOOK,CALL_OUTBOUND, 035600.14 4 xferType=33 otherLeg=1 035600.14 4 path {tdx_sethook} not found 035600.14 1 tw DialogicEvent 135,RLS_LCSENSE,0,0,0,DX_OFFHOOK,CALL_OUTBOUND, 035600.16 1 event RLS_LCSENSE, iCode=135 state=1922 035600.16 1 LsXfer_6_dc_WaitOutcomeOutgoingCall_OutLeg : 135,[RLS_LCSENSE],0,0,0,DX_OFFHOOK,CALL_OUTBOUND, 035600.16 4 LsXfer_6_dc_WaitOutcomeOutgoingCall_InLeg : [RLS_LCSENSE], 135(EV_UNKNOWN_135),0,0,0,DX_OFFHOOK,CALL_OUTBOUND, 035600.16 4 xferType=33 otherLeg=1 035600.16 4 path {rls_lcsense} not found 035622.03 4 tw DialogicEvent 134,TDX_CST,192,0,0,DE_TONEON,DISCONNECT_TAPI1, 035622.03 4 event DISCONNECT_TAPI1, iCode=134 state=1921 035622.03 4 LsXfer_6_dc_WaitOutcomeOutgoingCall_InLeg : [DISCONNECT_TAPI1], 134(EV_UNKNOWN_134),192,0,0,DE_TONEON,DISCONNECT_TAPI1, 035622.03 4 xferType=33 otherLeg=1 035622.03 4 outLeg line did not complete connection 035622.05 4 TsReset as DC not successful 100 035622.05 4 TsReset call from LsXfer_6_dc_WaitOutcomeOutgoingCall_InLeg 035622.05 4 path {disconnect_tapi1} not found 035622.05 4 next module is [Play 35] (idx=19) 035622.05 4 going down fail path 035622.05 4 fn RunModule start [Play,[Play 35],19,,] 035622.05 4 timer clear 035622.05 4 Play Module start 035622.05 4 state [Play 35] Playing 035622.07 4 state [Play 35] Playing (fail) 035622.07 4 File not found [fail], DirSysVoice=[C:\Program Files\VoiceGuide\system\voice\] (vox tried as well) 035622.07 4 tw ConvertWav2Vox C:\Program Files\VoiceGuide\system\voice\SoundFileNotFound.wav 035622.07 4 event TDX_CST, iCode=134 state=1100 035622.07 4 LsPlayMsg EV_UNKNOWN_134,TDX_CST 035622.07 4 path {TDX_CST} not found 035622.07 4 tw wav->vox convert end 799406,C:\Program Files\VoiceGuide\system\voice\SoundFileNotFound.vox,1,0,, 035622.08 4 play start ok, lPlayId=799406 035625.27 4 tw PlayEnd 4 799406 035625.27 4 play end id=799406, (current ID) 035625.27 4 event EV_PLAY_FINISHED, iCode=8001 state=1100 035625.27 4 LsPlayMsg EV_PLAY_FINISHED,EV_PLAY_FINISHED 035625.27 4 path {EV_PLAY_FINISHED} not found 035625.27 4 timer set 5 EV_TIMEOUT_REPLAYMSG 035625.27 4 tw DialogicEvent 129,TDX_PLAY,799406,0,0,,, 035625.27 4 event TDX_PLAY, iCode=129 state=1101 035625.27 4 LsPlayMsgFinished EV_UNKNOWN_129,TDX_PLAY 035625.27 4 path {TDX_PLAY} not found 035630.67 4 timer fired EV_TIMEOUT_REPLAYMSG 035630.67 4 event EV_TIMEOUT_REPLAYMSG, iCode=9005 state=1101 035630.67 4 LsPlayMsgFinished EV_TIMEOUT_REPLAYMSG,EV_TIMEOUT_REPLAYMSG 035630.67 4 path {EV_TIMEOUT_REPLAYMSG} not found 035630.67 4 state [Play 35] Playing (fail) 035630.67 4 File not found [fail], DirSysVoice=[C:\Program Files\VoiceGuide\system\voice\] (vox tried as well) 035630.67 4 tw ConvertWav2Vox C:\Program Files\VoiceGuide\system\voice\SoundFileNotFound.wav 035630.69 4 tw wav->vox convert end 808015,C:\Program Files\VoiceGuide\system\voice\SoundFileNotFound.vox,1,0,, 035630.71 4 play start ok, lPlayId=808046 035633.89 4 tw PlayEnd 4 808046 035633.89 4 play end id=808046, (current ID) 035633.89 4 event EV_PLAY_FINISHED, iCode=8001 state=1100 035633.89 4 LsPlayMsg EV_PLAY_FINISHED,EV_PLAY_FINISHED 035633.89 4 path {EV_PLAY_FINISHED} not found 035633.89 4 timer set 5 EV_TIMEOUT_REPLAYMSG 035633.89 4 tw DialogicEvent 129,TDX_PLAY,808046,0,0,,, 035633.89 4 event TDX_PLAY, iCode=129 state=1101 035633.91 4 LsPlayMsgFinished EV_UNKNOWN_129,TDX_PLAY 035633.91 4 path {TDX_PLAY} not found 035639.32 4 timer fired EV_TIMEOUT_REPLAYMSG 035639.32 4 event EV_TIMEOUT_REPLAYMSG, iCode=9005 state=1101 035639.32 4 LsPlayMsgFinished EV_TIMEOUT_REPLAYMSG,EV_TIMEOUT_REPLAYMSG 035639.32 4 path {EV_TIMEOUT_REPLAYMSG} not found 035639.32 4 state [Play 35] Playing (fail) 035639.32 4 File not found [fail], DirSysVoice=[C:\Program Files\VoiceGuide\system\voice\] (vox tried as well) 035639.32 4 tw ConvertWav2Vox C:\Program Files\VoiceGuide\system\voice\SoundFileNotFound.wav 035639.33 4 tw wav->vox convert end 816656,C:\Program Files\VoiceGuide\system\voice\SoundFileNotFound.vox,1,0,, 035639.35 4 play start ok, lPlayId=816671 035642.52 4 tw PlayEnd 4 816671 035642.52 4 play end id=816671, (current ID) 035642.52 4 event EV_PLAY_FINISHED, iCode=8001 state=1100 035642.52 4 LsPlayMsg EV_PLAY_FINISHED,EV_PLAY_FINISHED 035642.53 4 path {EV_PLAY_FINISHED} not found 035642.53 4 timer set 10 EV_TIMEOUT_HANGUP 035642.53 4 HangupCall start (no paths leaving play module [Play 35]) 035642.53 4 rv add [Hangup Time]{10/10/2006 3:56:42 AM} 035642.53 4 state Hanging up call... [no paths leaving play module [Play 35]] 035642.53 4 HangupCall_Common hCall=4 035642.53 4 rec RecSoundStop ok 035642.53 4 play PlayStop ok 035642.53 4 timer set 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP 035642.55 4 fnHangupCall end 035642.55 4 tw DialogicEvent 129,TDX_PLAY,816671,0,0,,, 035642.55 4 event TDX_PLAY, iCode=129 state=900 035642.55 4 LsAwaitingCalls EV_UNKNOWN_129 035642.58 4 tw DialogicEvent 135,TDX_SETHOOK,0,0,0,DX_ONHOOK,, 035642.58 4 event TDX_SETHOOK, iCode=135 state=900 035642.58 4 LsAwaitingCalls EV_UNKNOWN_135 035642.60 4 event callstate IDLE 4 1,0,0 035642.60 4 WorkingMode@Idle= 035642.60 4 set LineState().hCall = 0 LineEvCallState-LINECALLSTATE_IDLE 035642.60 4 timer clear 035642.60 4 rec RecSoundStop ok 035642.60 4 play PlayStop ok 035642.60 4 rv add [CallEndTime]{10/10/2006 3:56:42 AM} 035642.60 4 timer set 1 EV_TIMEOUT_TIMETOREINITLINE 035643.58 4 timer fired EV_TIMEOUT_TIMETOREINITLINE 035643.58 4 event EV_TIMEOUT_TIMETOREINITLINE, iCode=9008 state=900 035643.58 4 init atidle reinit : start 035643.58 4 init atidle reinit iConferenceOtherLegLid=-1 035643.58 4 init atidle reinit : reset all LineState variables 035643.58 4 timer set 2 EV_TIMEOUT_AFTERIDLE_ALLOWOUT 035643.58 4 state Waiting for a call... 035645.77 4 timer fired EV_TIMEOUT_AFTERIDLE_ALLOWOUT 035645.77 4 event EV_TIMEOUT_AFTERIDLE_ALLOWOUT, iCode=9013 state=900 035645.77 4 setting iDialoutReadyToDialout=1 THANKS A LOT IN ADVANCE !!! Share this post Link to post
SupportTeam Report post Posted 10/10/2006 08:15 PM I am using D/4 PCIUF card. I read somewhere that this card cannot be used to do call transfer. Is that true ? Yes. Only cards which have "SC-Bus" or "CT-Bus" can do Dial And Conference. "Dial and Conference" can only be done with these Dialogic cards: D/41EPCI, D/41ESC, D/41JCTLS, D/120JCTLS, D/160SC-LS and all digital cards (D/240, D/300 etc), and all 'DMV' cards (DMV160, DMV600, DMV1200 etc). Anyway, how does dial and conference work? I have 2 phone lines plugged into the card. I will call on one, then voice guide will use the other line to dial any number? Like I can simply specify a 10 digit cell phone number (xxx)-xxx-xxxx ? Yes. Any number can be dialed on the other line. It's just a new call... When posting traces/scripts please .ZIP them up and post them as attachments. Share this post Link to post
frequency34 Report post Posted 10/26/2006 07:48 AM From the cards that you mentioned, which one should I buy ? can you provide some help regarding this ? I was using the D4/PCIUF card. It was working perfect until i came to the part where i had to implement call transfer. (I am going to use the dial and conference method) Dialogic cards: D/41EPCI, D/41ESC, D/41JCTLS, D/120JCTLS, D/160SC-LS <---- will any of these cards work just as good as the D4/PCIUF card did + will support the call transfer module ? thanks in advance Share this post Link to post
SupportTeam Report post Posted 10/26/2006 08:24 AM All analog Dialogic cards support "Hookflash" type transfers. Only some analog Dialogic cards support "Dial and Conference" type transfers. Only cards which have "SC-Bus" or "CT-Bus" can do Dial And Conference. "Dial and Conference" can only be done with these Dialogic cards: D/41EPCI, D/41ESC, D/41JCTLS, D/120JCTLS, D/160SC-LS and all digital cards (D/240, D/300 etc), and all 'DMV' cards (DMV160, DMV600, DMV1200 etc). The cheapest card that supports "Dial and Conference" type transfers is the D/41JCTLS. Share this post Link to post
ktruk Report post Posted 10/31/2006 04:40 PM Frequency34: Your telephone line supplier can sometimes supply a "conferancing line" to you. This allows you to make two calls on one line at a time, using 'flash-hooks' to switch between calls which are handled at your exchange. Using this facility, your current dialogic card could (in theory) confereance the call out to a mobile or other number, without attempting to connect two lines. You might want to investigate this a little, before splashing out out on a new card. Contact your telephone company and ask about this facility. Warning, each telephone company have different names for this facility! In the UK its called 3-way calling. Your line will be tied up for the duration of the call and you bear the cost of the call. (but you do this anyway with 2 line connection). This can be enabled on your line for a few dollars a month subscription. Major issues with using this service is hangup detection, possible volume attentuation and getting the correct flash-hook sequence, and no-answer/busy detection, but it could be a solution. Share this post Link to post
