Call Transfer Issue
I need to implement call transfer..
Our office does not use a PBX, nor do we have the facility of 'extensions' by which by dialing the extension number an incoming call is transfered to the extension.
So I am guessing I will have to use the Dial and Conference Method to do call transfer.
I am using D/4 PCIUF card. I read somewhere that this card cannot be used to do call transfer. Is that true ?(if so then i am in big trouble since I already bought this card long back :(
Anyway, how does dial and conference work? I have 2 phone lines plugged into the card. I will call on one, then voice guide will use the other line to dial any number? Like I can simply specify a 10 digit cell phone number (xxx)-xxx-xxxx ?
Well when I use "Dialout and Conference Blind" I get the following message on the line which is supposed to make the outgoing call:
Dialing (xxx)-xxx-xxxx for conference with dxxxB1C4
But after that nothing happens, I do not receive any calls on the number i have specified.
How can I tell from the event trace log whether this is due to the card or is it something else...
Here is the log..
035554.63 4 event callstate OFFERING 4 2,0,0
035554.63 4 script interpretor: VgMulti v6.0.3157
035554.63 4 fired OFFERING event to listeners
035554.63 4 set LineState().hCall = 4 in LINECALLSTATE_OFFERING
035554.63 4 cid CallerID vars set (in 'offering' event) [,,]
035554.64 4 call AnswerTheCallIfAllowed from LINECALLSTATE_OFFERING
035554.64 4 rings=0, min rings before answer=0 (iCallerIdHasArrived=0)
035554.64 4 tw ring 1
035554.64 4 ring time since last ring event (sec): 0.00
035554.64 4 rings=1, min rings before answer=0 (iCallerIdHasArrived=0)
035554.64 4 should answer as number of rings reached
035554.64 4 rv clear all
035554.64 4 init LineState ResetAtStartOfNewCall.
035554.64 4 answering the call (,,,0)
035554.64 4 timer clear
035554.64 4 tw DialogicEvent 134,TDX_CST,0,0,0,DE_RINGS,ET_RON,
035554.64 4 event TDX_CST, iCode=134 state=6001
035554.64 4 LsModuleTransition : 134, [TDX_CST]
035555.28 4 tw DialogicEvent 135,TDX_SETHOOK,0,0,0,DX_OFFHOOK,CALL_INBOUND,
035555.28 4 event TDX_SETHOOK, iCode=135 state=6001
035555.28 4 LsModuleTransition : 135, [TDX_SETHOOK]
035555.28 4 event callstate CONNECTED 4 256,0,0
035555.28 4 LineEvCallState_Connected hDevice=4 params=256,0,0
035555.28 4 WorkingModes tapi= script= LineState().iState=6001
035556.28 4 Inband detection not enabled
035556.28 4 StartLoadedVgs at 10/10/2006 3:55:56 AM (VgMulti v6.0.3157)
035556.28 4 set LineState().iVgsIdx=3
035556.28 4 set sScriptToRunOnHangup=[] in StartLoadedVgs
035556.30 4 init StartLoadedVgs_InitLineState start
035556.30 4 rv add [$RV_STARTTIME]{10/10/2006 3:55:56 AM}
035556.30 4 rv add [$RV_DEVICEID]{4}
035556.30 4 rv add [$RV_CIDNAME]{}
035556.30 4 rvns add [PathApp]{C:\Program Files\VoiceGuide\}
035556.30 4 rvns add [scriptsPath]{C:\Program Files\VoiceGuide\Scripts\version 7\}
035556.30 4 rv add [$RV_CIDNUMBER]{}
035556.30 4 fn RunModule start [Play,[Play 1],16,,]
035556.30 4 tw DialogicEvent 134,TDX_CST,25721,0,0,DE_LCON,,
035556.30 4 event TDX_CST, iCode=134 state=6001
035556.30 4 LsModuleTransition : 134, [TDX_CST]
035556.32 4 timer clear
035556.32 4 Play Module start
035556.32 4 state [Play 1] Playing
035556.32 4 tts deleted previous C:\Program Files\VoiceGuide\data\tts_4_1.wav
035556.32 4 tts generate start[hello. transfering call..]
035556.32 4 tts generate wait
035556.35 4 tts generate finish
035556.35 4 state [Play 1] Playing (C:\Program Files\VoiceGuide\data\tts_4_1.wav)
035556.35 4 tw ConvertWav2Vox C:\Program Files\VoiceGuide\data\tts_4_1.wav
035556.36 4 tw wav->vox convert end 773687,C:\Program Files\VoiceGuide\data\tts_4_1.vox,1,0,,
035556.38 4 play start ok, lPlayId=773718
035559.14 4 tw PlayEnd 4 773718
035559.16 4 play end id=773718, (current ID)
035559.16 4 event EV_PLAY_FINISHED, iCode=8001 state=1100
035559.16 4 LsPlayMsg EV_PLAY_FINISHED,EV_PLAY_FINISHED
035559.16 4 path {EV_PLAY_FINISHED} not found
035559.16 4 timer set 10 EV_TIMEOUT_HANGUP
035559.16 4 timer set 0 EV_TIMEOUT_GOTOMODULE
035559.16 4 event EV_TIMEOUT_GOTOMODULE, iCode=9002 state=1101
035559.16 4 LsPlayMsgFinished EV_TIMEOUT_GOTOMODULE,EV_TIMEOUT_GOTOMODULE
035559.16 4 path {EV_TIMEOUT_GOTOMODULE} not found
035559.16 4 next module is [Transfer Call 33] (idx=17)
035559.16 4 fn RunModule start [Transfer Call,[Transfer Call 33],17,,]
035559.16 4 tw DialogicEvent 129,TDX_PLAY,773718,0,0,,,
035559.17 4 event TDX_PLAY, iCode=129 state=6001
035559.17 4 LsModuleTransition : 129, [TDX_PLAY]
035559.17 4 timer clear
035559.17 4 timer set 0.4 EV_TIMEOUT_READYTOBEGINTRANSFER
035559.58 4 timer fired EV_TIMEOUT_READYTOBEGINTRANSFER
035559.58 4 event EV_TIMEOUT_READYTOBEGINTRANSFER, iCode=9012 state=1901
035559.58 4 LsXfer_1_Start : 9012(EV_TIMEOUT_READYTOBEGINTRANSFER),EV_TIMEOUT_READYTOBEGINTRANSFER,0,0,0,,,
035559.58 4 path {EV_TIMEOUT_READYTOBEGINTRANSFER} not found
035559.58 4 timeout on transfer attempt set by VG.INI [PBX] AnnouncedTransfersMaxWaitTime (30 sec)
035559.58 4 timer set 30 EV_TIMEOUT_ANNOUNCED_TRANSFER_ATTEMPT_TOOK_TOO_LONG
035559.58 4 state [Transfer Call 33] Announced Dial and Connect to 13522262369
035559.58 dial search for free lines in LineID range [0-4]
035559.58 1 dial reserving: no list specified
035559.58 4 dial found free dev=1 (LineId=1) in XferDialAndConference
035559.58 4 no on-hold file specified to play
035559.60 1 state dialing 13522262369 (for conference with dxxxB1C4) iXferBridgeCallsWhen=0, sCallProgressOption=CONNECT_IMMEDIATELY (Immediately after dialing.)
035559.60 1 lineMakeCall(13522262369,CONNECT_IMMEDIATELY) (in XferDialAndConference) => 0
035559.60 1 call progress option selected: Immediately after dialing.
035559.60 4 announced DC transfer (33)
035600.14 1 tw DialogicEvent 135,TDX_SETHOOK,0,0,0,DX_OFFHOOK,CALL_OUTBOUND,
035600.14 1 event TDX_SETHOOK, iCode=135 state=1922
035600.14 1 LsXfer_6_dc_WaitOutcomeOutgoingCall_OutLeg : 135,[TDX_SETHOOK],0,0,0,DX_OFFHOOK,CALL_OUTBOUND,
035600.14 4 LsXfer_6_dc_WaitOutcomeOutgoingCall_InLeg : [TDX_SETHOOK], 135(EV_UNKNOWN_135),0,0,0,DX_OFFHOOK,CALL_OUTBOUND,
035600.14 4 xferType=33 otherLeg=1
035600.14 4 path {tdx_sethook} not found
035600.14 1 tw DialogicEvent 135,RLS_LCSENSE,0,0,0,DX_OFFHOOK,CALL_OUTBOUND,
035600.16 1 event RLS_LCSENSE, iCode=135 state=1922
035600.16 1 LsXfer_6_dc_WaitOutcomeOutgoingCall_OutLeg : 135,[RLS_LCSENSE],0,0,0,DX_OFFHOOK,CALL_OUTBOUND,
035600.16 4 LsXfer_6_dc_WaitOutcomeOutgoingCall_InLeg : [RLS_LCSENSE], 135(EV_UNKNOWN_135),0,0,0,DX_OFFHOOK,CALL_OUTBOUND,
035600.16 4 xferType=33 otherLeg=1
035600.16 4 path {rls_lcsense} not found
035622.03 4 tw DialogicEvent 134,TDX_CST,192,0,0,DE_TONEON,DISCONNECT_TAPI1,
035622.03 4 event DISCONNECT_TAPI1, iCode=134 state=1921
035622.03 4 LsXfer_6_dc_WaitOutcomeOutgoingCall_InLeg : [DISCONNECT_TAPI1], 134(EV_UNKNOWN_134),192,0,0,DE_TONEON,DISCONNECT_TAPI1,
035622.03 4 xferType=33 otherLeg=1
035622.03 4 outLeg line did not complete connection
035622.05 4 TsReset as DC not successful 100
035622.05 4 TsReset call from LsXfer_6_dc_WaitOutcomeOutgoingCall_InLeg
035622.05 4 path {disconnect_tapi1} not found
035622.05 4 next module is [Play 35] (idx=19)
035622.05 4 going down fail path
035622.05 4 fn RunModule start [Play,[Play 35],19,,]
035622.05 4 timer clear
035622.05 4 Play Module start
035622.05 4 state [Play 35] Playing
035622.07 4 state [Play 35] Playing (fail)
035622.07 4 File not found [fail], DirSysVoice=[C:\Program Files\VoiceGuide\system\voice\] (vox tried as well)
035622.07 4 tw ConvertWav2Vox C:\Program Files\VoiceGuide\system\voice\SoundFileNotFound.wav
035622.07 4 event TDX_CST, iCode=134 state=1100
035622.07 4 LsPlayMsg EV_UNKNOWN_134,TDX_CST
035622.07 4 path {TDX_CST} not found
035622.07 4 tw wav->vox convert end 799406,C:\Program Files\VoiceGuide\system\voice\SoundFileNotFound.vox,1,0,,
035622.08 4 play start ok, lPlayId=799406
035625.27 4 tw PlayEnd 4 799406
035625.27 4 play end id=799406, (current ID)
035625.27 4 event EV_PLAY_FINISHED, iCode=8001 state=1100
035625.27 4 LsPlayMsg EV_PLAY_FINISHED,EV_PLAY_FINISHED
035625.27 4 path {EV_PLAY_FINISHED} not found
035625.27 4 timer set 5 EV_TIMEOUT_REPLAYMSG
035625.27 4 tw DialogicEvent 129,TDX_PLAY,799406,0,0,,,
035625.27 4 event TDX_PLAY, iCode=129 state=1101
035625.27 4 LsPlayMsgFinished EV_UNKNOWN_129,TDX_PLAY
035625.27 4 path {TDX_PLAY} not found
035630.67 4 timer fired EV_TIMEOUT_REPLAYMSG
035630.67 4 event EV_TIMEOUT_REPLAYMSG, iCode=9005 state=1101
035630.67 4 LsPlayMsgFinished EV_TIMEOUT_REPLAYMSG,EV_TIMEOUT_REPLAYMSG
035630.67 4 path {EV_TIMEOUT_REPLAYMSG} not found
035630.67 4 state [Play 35] Playing (fail)
035630.67 4 File not found [fail], DirSysVoice=[C:\Program Files\VoiceGuide\system\voice\] (vox tried as well)
035630.67 4 tw ConvertWav2Vox C:\Program Files\VoiceGuide\system\voice\SoundFileNotFound.wav
035630.69 4 tw wav->vox convert end 808015,C:\Program Files\VoiceGuide\system\voice\SoundFileNotFound.vox,1,0,,
035630.71 4 play start ok, lPlayId=808046
035633.89 4 tw PlayEnd 4 808046
035633.89 4 play end id=808046, (current ID)
035633.89 4 event EV_PLAY_FINISHED, iCode=8001 state=1100
035633.89 4 LsPlayMsg EV_PLAY_FINISHED,EV_PLAY_FINISHED
035633.89 4 path {EV_PLAY_FINISHED} not found
035633.89 4 timer set 5 EV_TIMEOUT_REPLAYMSG
035633.89 4 tw DialogicEvent 129,TDX_PLAY,808046,0,0,,,
035633.89 4 event TDX_PLAY, iCode=129 state=1101
035633.91 4 LsPlayMsgFinished EV_UNKNOWN_129,TDX_PLAY
035633.91 4 path {TDX_PLAY} not found
035639.32 4 timer fired EV_TIMEOUT_REPLAYMSG
035639.32 4 event EV_TIMEOUT_REPLAYMSG, iCode=9005 state=1101
035639.32 4 LsPlayMsgFinished EV_TIMEOUT_REPLAYMSG,EV_TIMEOUT_REPLAYMSG
035639.32 4 path {EV_TIMEOUT_REPLAYMSG} not found
035639.32 4 state [Play 35] Playing (fail)
035639.32 4 File not found [fail], DirSysVoice=[C:\Program Files\VoiceGuide\system\voice\] (vox tried as well)
035639.32 4 tw ConvertWav2Vox C:\Program Files\VoiceGuide\system\voice\SoundFileNotFound.wav
035639.33 4 tw wav->vox convert end 816656,C:\Program Files\VoiceGuide\system\voice\SoundFileNotFound.vox,1,0,,
035639.35 4 play start ok, lPlayId=816671
035642.52 4 tw PlayEnd 4 816671
035642.52 4 play end id=816671, (current ID)
035642.52 4 event EV_PLAY_FINISHED, iCode=8001 state=1100
035642.52 4 LsPlayMsg EV_PLAY_FINISHED,EV_PLAY_FINISHED
035642.53 4 path {EV_PLAY_FINISHED} not found
035642.53 4 timer set 10 EV_TIMEOUT_HANGUP
035642.53 4 HangupCall start (no paths leaving play module [Play 35])
035642.53 4 rv add [Hangup Time]{10/10/2006 3:56:42 AM}
035642.53 4 state Hanging up call... [no paths leaving play module [Play 35]]
035642.53 4 HangupCall_Common hCall=4
035642.53 4 rec RecSoundStop ok
035642.53 4 play PlayStop ok
035642.53 4 timer set 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP
035642.55 4 fnHangupCall end
035642.55 4 tw DialogicEvent 129,TDX_PLAY,816671,0,0,,,
035642.55 4 event TDX_PLAY, iCode=129 state=900
035642.55 4 LsAwaitingCalls EV_UNKNOWN_129
035642.58 4 tw DialogicEvent 135,TDX_SETHOOK,0,0,0,DX_ONHOOK,,
035642.58 4 event TDX_SETHOOK, iCode=135 state=900
035642.58 4 LsAwaitingCalls EV_UNKNOWN_135
035642.60 4 event callstate IDLE 4 1,0,0
035642.60 4 WorkingMode@Idle=
035642.60 4 set LineState().hCall = 0 LineEvCallState-LINECALLSTATE_IDLE
035642.60 4 timer clear
035642.60 4 rec RecSoundStop ok
035642.60 4 play PlayStop ok
035642.60 4 rv add [CallEndTime]{10/10/2006 3:56:42 AM}
035642.60 4 timer set 1 EV_TIMEOUT_TIMETOREINITLINE
035643.58 4 timer fired EV_TIMEOUT_TIMETOREINITLINE
035643.58 4 event EV_TIMEOUT_TIMETOREINITLINE, iCode=9008 state=900
035643.58 4 init atidle reinit : start
035643.58 4 init atidle reinit iConferenceOtherLegLid=-1
035643.58 4 init atidle reinit : reset all LineState variables
035643.58 4 timer set 2 EV_TIMEOUT_AFTERIDLE_ALLOWOUT
035643.58 4 state Waiting for a call...
035645.77 4 timer fired EV_TIMEOUT_AFTERIDLE_ALLOWOUT
035645.77 4 event EV_TIMEOUT_AFTERIDLE_ALLOWOUT, iCode=9013 state=900
035645.77 4 setting iDialoutReadyToDialout=1
THANKS A LOT IN ADVANCE !!! :)
Yes. Only cards which have "SC-Bus" or "CT-Bus" can do Dial And Conference.
"Dial and Conference" can only be done with these Dialogic cards: D/41EPCI, D/41ESC, D/41JCTLS, D/120JCTLS, D/160SC-LS and all digital cards (D/240, D/300 etc), and all 'DMV' cards (DMV160, DMV600, DMV1200 etc).
Yes. Any number can be dialed on the other line. It's just a new call...
From the cards that you mentioned, which one should I buy ? can you provide some help regarding this ?
I was using the D4/PCIUF card. It was working perfect until i came to the part where i had to implement call transfer. (I am going to use the dial and conference method)
Dialogic cards: D/41EPCI, D/41ESC, D/41JCTLS, D/120JCTLS, D/160SC-LS <---- will any of these cards work just as good as the D4/PCIUF card did + will support the call transfer module ?
thanks in advance
All analog Dialogic cards support "Hookflash" type transfers.
Only some analog Dialogic cards support "Dial and Conference" type transfers.
The cheapest card that supports "Dial and Conference" type transfers is the D/41JCTLS.
Frequency34: Your telephone line supplier can sometimes supply a "conferancing line" to you. This allows you to make two calls on one line at a time, using 'flash-hooks' to switch between calls which are handled at your exchange. Using this facility, your current dialogic card could (in theory) confereance the call out to a mobile or other number, without attempting to connect two lines.
You might want to investigate this a little, before splashing out out on a new card. Contact your telephone company and ask about this facility. Warning, each telephone company have different names for this facility! In the UK its called 3-way calling. Your line will be tied up for the duration of the call and you bear the cost of the call. (but you do this anyway with 2 line connection). This can be enabled on your line for a few dollars a month subscription. Major issues with using this service is hangup detection, possible volume attentuation and getting the correct flash-hook sequence, and no-answer/busy detection, but it could be a solution.
