Play Message And Transfer..
Hi..
So here it goes..
1) caller calls, vg answers ..
2) caller presses 9 for operator
3) now what? i want vg to play a message "please hold on your call is being transffered" ..
if i use only the t.call module, no pre-message is heard..
if i use the play message module, how do i transfer it after 0 seconds to the transfer block?
tried timeout =0 or timeout=1 but it wont work..
what is the right procedure?
im sure its simple..
thnx!
To play "please hold on your call is being transferred" message just use a Play module with the number of replays set to 0 - that way the sound file in that module will only be played once.
Then use a timeout 0 path.
Immediately after playing the sound file the system will go onto the next module - transfer module in this case.
See attached example script.
PlayPleaseHoldBeforeTransfer.vgs
