Tts Failure
After a few hours of use the text to speech capabilities fail on our VoiceGuide system. I have noticed that this occurs typically after a Script GoTo event is called leading a user to another script. A great deal of our TTS is comprised of $RV variables based on database queries. A restart of VoiceGuide brings the text to speech back up.
Which TTS engine is used on this system?
[Log]
VoiceGuide=10
NumberLoader=0
VoicemailManager=0
EmailSender=0
TapiWrapOcx=10
SapiWrapOcx=10
Then restart VG and wait thill the problem occurs.
Indicate time/call when problem occurred.
