XOLimited Report post Posted 10/19/2006 04:46 AM Hi there, We currently have a script that retrives text from an SQL 2005 database - When entering the RV in the 'text to speak:' field of a Play Sound module, the TTS engine fails to play the data. Is there a way of solving this, Thanks Tim Share this post Link to post
SupportTeam Report post Posted 10/19/2006 04:50 AM Enable logging by setting the log levels to 10 in VG.INI as per below: [Log] VoiceGuide=10 NumberLoader=0 VoicemailManager=0 EmailSender=0 TapiWrapOcx=10 SapiWrapOcx=10 Then restart VG and make a test call which demonstrates the problem. Debug Trace files will be created in VG's \log\ subdirectory. Please post the traces and the VoiceGuide script used. When posting traces/scripts please .ZIP them up and post them as attachments. Share this post Link to post
XOLimited Report post Posted 10/19/2006 09:46 PM Thanks File attached Tim 1020sw.zip Share this post Link to post
SupportTeam Report post Posted 10/19/2006 10:02 PM Trace shows that database query in module [userID-Lookup] returned one result row: 104209.41 0 state [userID-Lookup] DB Query 104209.41 0 db ODBC mode used 104209.64 0 db About to execute a Retrieve type operation [select firstname from [user] where UserID = 56] 104209.64 0 db [userID-Lookup] row count=1 104209.64 0 rv lg add [userID-Lookup_RowCount]{1} but then in module [Play 9] the script is told to play $RV[userID-Lookup] $RV[userID-Lookup] is not a valid RV. You should be using: $RV[userID-Lookup_1_1] ( $RV[userID-Lookup_1] will work as well I think ). See the Help file section of DBQuery module to see what RVs are created by that module: http://www.voiceguide.com/vghelp/html/modDbQuery.htm Share this post Link to post
