Tts Reading Result From Query
Hi there,
We currently have a script that retrives text from an SQL 2005 database - When entering the RV in the 'text to speak:' field of a Play Sound module, the TTS engine fails to play the data.
Is there a way of solving this,
Tim
[Log]
VoiceGuide=10
NumberLoader=0
VoicemailManager=0
EmailSender=0
TapiWrapOcx=10
SapiWrapOcx=10
Debug Trace files will be created in VG's \log\ subdirectory.
Trace shows that database query in module [userID-Lookup] returned one result row:
104209.41 0 state [userID-Lookup] DB Query
104209.41 0 db ODBC mode used
104209.64 0 db About to execute a Retrieve type operation [select firstname from [user] where UserID = 56]
104209.64 0 db [userID-Lookup] row count=1
104209.64 0 rv lg add [userID-Lookup_RowCount]{1}
but then in module [Play 9] the script is told to play $RV[userID-Lookup]
$RV[userID-Lookup] is not a valid RV.
You should be using:
$RV[userID-Lookup_1_1]
( $RV[userID-Lookup_1] will work as well I think ).
See the Help file section of DBQuery module to see what RVs are created by that module: http://www.voiceguide.com/vghelp/html/modDbQuery.htm
