Guest Gulano Report post Posted 10/20/2006 08:20 PM Hallo Support Team, Our company company purchased the VoiceGuide Enterprise 8 line license but I do not activate it yet because I don't know which voiceguide I must or will use to setup a IVR Sysem. I installed a windows 2000 Advanced Server with a D/4PCIU4S card, a D/4PCIUF card and the voiceguide software. I also installed SR5.1.1 + SR5.1.1 SP1 + D4PCIU support. I have some questions. Questions: 1) Is there a physical difference between the 2 cards because in the DCM I see 2 D/4PCIU boards are detected. 2) Where can I find a manual or a link where I can find information to work with voiceguide for dialogic? 3) Do I will have problems because I am using the w2k server using voiceguide + dialogic? The company where we purchaded the cards give us the R6.0 drivers but when I installed the drivers voicguide cannot see the lines. 3) What is the best I can do? Regards, Gulano Share this post Link to post
SupportTeam Report post Posted 10/20/2006 11:14 PM Quote 1) Is there a physical difference between the 2 cards because in the DCM I see 2 D/4PCIU boards are detected.There is, but the D/4PCIU support pack for SR5.1.1SP1 will detect them both as D/4PCIU cards. Quote 2) Where can I find a manual or a link where I can find information to work with voiceguide for dialogic? There is a Help file. It's installed when you install VG. Quote 3) Do I will have problems because I am using the w2k server using voiceguide + dialogic?No. Win2000 Server is fine. Quote The company where we purchaded the cards give us the R6.0 drivers but when I installed the drivers voicguide cannot see the lines.You should use SR6.0. Make sure to use VoiceGuide for Dialogic. VoiceGuide for Dialogic when installed is pre-configured to work with 4 lines and it will see the lines immediately if the Dialogic System Release service is started. Use the Dialogic Configuration Manager (DCM) to confirm the drivers are started. Share this post Link to post
Guest Gulano Report post Posted 10/24/2006 05:14 PM Hallo Support Team, I installed VoiceGuide for Dialogic and it is working with SR6.0. In the config.xml file you can specify which *.vgs script you want to use for a specified channel. This is new for me so I went to the Internet to find information about how to create a voice xml file. Question: 1) How can you configure vg to use a xml file for IVR options? For example: I copy this from the config.xml file which is configured to use the Credit Card Payment.vgs script. <?xml version="1.0"?> <VoiceGuideConfig> <Devices_Dialogic> <Channels> <Channel> <Name>dxxxB1C1</Name> <NetworkIf>dxxxB1C1</NetworkIf> <Protocol>pdk_na_an_io</Protocol> <RingsBeforeAnswer>0</RingsBeforeAnswer> <script>C:\Program Files\VoiceGuide\Scripts\Credit Card Payment\Credit Card Payment.vgs</Script> <AllowDialOut>1</AllowDialOut> </Channel> <Channel> Regards, Gulano Share this post Link to post
SupportTeam Report post Posted 10/24/2006 09:37 PM VoiceGuide will automatically use Config.xml file in VG's \data\ subdirectory. To set VG to use a different script change the <script> field to specify a different .vgs file, and restart VG. The new Config.xml settings will then get loaded. Share this post Link to post
Guest Gulano Report post Posted 10/25/2006 12:24 PM Hello Support Team, Sorry that I was not clear. I meant to say that: How can I configure VG to use a xml file that I made by my self? For example the file: MY-FIRST-FILE.XML Question: How can I configure VG to use this file?: MY-FIRST-FILE.XML I don't know if I did it the right way. <?xml version="1.0"?> <VoiceGuideConfig> <Devices_Dialogic> <Channels> <Channel> <Name>dxxxB1C1</Name> <NetworkIf>dxxxB1C1</NetworkIf> <Protocol>pdk_na_an_io</Protocol> <RingsBeforeAnswer>0</RingsBeforeAnswer> <script>C:\Program Files\VoiceGuide\Scripts\MY-FIRST-FILE.XML </Script> <AllowDialOut>1</AllowDialOut> </Channel> <Channel> I hope you can help me with this configuration. Regards, Gulano Share this post Link to post
SupportTeam Report post Posted 10/25/2006 10:09 PM The <script> entry is used to specify a VoiceGuide Script (a .vgs file). Use the VoiceGuide Script Designer to create a VoiceGuide Script (a .vgs file). Share this post Link to post
Guest Gulano Report post Posted 10/26/2006 01:27 PM Ok thanks, It's clear. Regards Share this post Link to post
