Communicating With Dtmf
I hope some of you have realworld experience with this one.
I have an applicaton that users normally use the internet to check the status of something.
But some new clients don't have Internet access.
1) I want to have a customer call one of my clients.
2) the caller id is recorded at the client's site (using VoiceGuide)
3) i want to place the customer on hold using the telco's 3-way calling feature.
4) I want to switch-hook, then dial a server running VoiceGuide
5) The server sees the caller id and recogizes it as one of my clients
6) It answers the phone and issues a tone.
7) the calling VoiceGuide computer at the client's site recognizes that as it's prompt to give a 10 digit number in DTMF
8) My server receives the DTMFs and then looks up the data.
9) The data (a 5 digit code) is sent back to the client's computer via DTMF
10) switch-hook and back to caller's session.
I live in Florida with a fairly fast telco. How long should the above process take. I am trying to judge if it is an acceptable delay for the customer.
Any input would be appreciated.
Thanks,
Bill Compton
100ms (or even shorter) DTMF tone is adequate here...
Standard modems is to have each tone on for 100 ms, and a pause of 100ms in between - so 10 digits would take 2 seconds to play. Dialogic cards can have the DTMF times set, and many phone systems will recognize a 50ms DTMF tone with a 50ms pause - so you could play the whole 10 digits in one second.
I imagine the database lookup would take about half a second...
around one second, or half a second if you use the faster tones and your modem/card can recognize them.
hookflash takes about 100ms usually.
So when you add the above that’s between 2.5 and 4 seconds.
you will still need to add the time taken by point 4 into the equation.
Please note that soon you will also be able with VoiceGuide to make an external call on another line and bridge the two calls together - so you will not need to use the 3way calling feature but can have a direct connection.
