Guest gymcoach5 Report post Posted 10/23/2006 04:01 AM When I select "Set and Run Current Script" I get the folowing error: VgMulti.exe has generated errors and will be closed by Windows. You will need to restart the program. An error log is being created. Share this post Link to post
SupportTeam Report post Posted 10/23/2006 04:08 AM Which version of VoiceGuide are you using? Share this post Link to post
Guest gymcoach5 Report post Posted 10/23/2006 12:14 PM Version 6.0.3107 VoiceGuide for Dialogic Share this post Link to post
Guest gymcoach5 Report post Posted 10/23/2006 02:31 PM It is running on a Windows 2000 machine with SP4. I am also using a Dialogic D/4PCIU Card. Share this post Link to post
SupportTeam Report post Posted 10/23/2006 11:45 PM I think you must be using an older incompatible version of the Script Designer. The version of Script Designer intended to be used with VG for Dialogic does not even have the "Set and Run Current Script" option available as the script specification is made in Config.xml file. It's probably best for you to uninstall what is currently on system and install the latest version of VG for Dialogic available from our WWW. Share this post Link to post
