Script To Record Messages
Hi everyone,
I am new with Voice Guide. I tried to make a script but it's giving me a head pain.
Is there someone who can help me with this "Simple" script?
I want to record a call.
1) After record the call It must be posible to listen to the message
2) I must be able to delete it or save it in a mailbox
The only things I have done are:
1) I use 1 play sound module
2) I configure it to play a sound file which five the information what to do
3) I use a record module
3) After pressing key 1 the script is going to the record module.
you can hear a beep and the caller can speak the message
And here is my problem. I can't go further.
Is there someone who can help me with this configuration?
Thank you so much,
Jennifer
I think you should be looking at just using a Voicemail box. See: http://www.voiceguide.com/vghelp/html/Voic...ntroduction.htm
The Voicemail system is written as a set of VoiceGuide scripts located in VoiceGuide's \system\vm\ directory. These scripts can be edited giving the user full control and freedom over any modifications and extensions which may be required of the voicemail system.
