Guest ecard Report post Posted 10/29/2006 05:03 PM When I run the VBscript on your sample 6. I got error message 'Loading script 'C:/programe files/voiceguide/temp/vbs....' failed (access is denied"' Any helps are apreciated Share this post Link to post
SupportTeam Report post Posted 10/29/2006 11:11 PM Are you running the script form within the Run VBScript module? Please enable logging by setting the log levels to 10 in VG.INI as per below: Quote [Log] VoiceGuide=10 Then restart VG and make a test call which demonstrates the problem. Debug Trace files will be created in VG's \log\ subdirectory. Please post the traces and the VoiceGuide script used. When posting traces/scripts please .ZIP them up and post them as attachments. Share this post Link to post
Guest ecard Report post Posted 10/31/2006 02:47 AM Thanks for your quick response. Yes, I'm runing the script form within the Run VBScript module. Here's the script Dim WordApp Dim myWordDoc Dim strPathDoc Dim intRecord Set WordApp = CreateObject("word.application") WordApp.Visible = True strPathDoc = "c:\info\prices1.doc" Set myWordDoc = WordApp.Documents.Open(strPathDoc) myWordDoc.ActiveWindow.Document.SendFax("5554321") 'always deallocate after use... Set myWordDoc = Nothing Set WordApp = Nothing The attachment is the trace log 1030sw.txt 1030tw.txt 1030vgm.txt Share this post Link to post
SupportTeam Report post Posted 10/31/2006 03:19 AM Can you post a screenshot of the error message which you see on the screen? It sounds like you are running VoiceGuide on an account which is not allowed to run VBScripts. Try running VG when logged in as Administrator. What is the "tango Access PPPoE Adapter" TAPI device which you are using on this system? Share this post Link to post
Guest ecard Report post Posted 11/18/2006 08:08 PM It's my computer personall firewall cause the problem. Share this post Link to post
SupportTeam Report post Posted 11/18/2006 11:01 PM Ah yes, sometimes the anti-virus applications etc will prevent VBScripts form being executed properly... Most anti-virus programs have options that allow you to enable full VBScript execution. Share this post Link to post
