Fax On Demand Failed
When I run the VBscript on your sample 6. I got error message
'Loading script 'C:/programe files/voiceguide/temp/vbs....' failed (access is denied"'
Any helps are apreciated
Are you running the script form within the Run VBScript module?
Please enable logging by setting the log levels to 10 in VG.INI as per below:
[Log]
VoiceGuide=10
Debug Trace files will be created in VG's \log\ subdirectory.
Thanks for your quick response.
Yes, I'm runing the script form within the Run VBScript module.
Here's the script
Dim WordApp
Dim myWordDoc
Dim strPathDoc
Dim intRecord
Set WordApp = CreateObject("word.application")
WordApp.Visible = True
strPathDoc = "c:\info\prices1.doc"
Set myWordDoc = WordApp.Documents.Open(strPathDoc)
myWordDoc.ActiveWindow.Document.SendFax("5554321")
'always deallocate after use...
Set myWordDoc = Nothing
Set WordApp = Nothing
The attachment is the trace log
1030sw.txt
1030tw.txt
1030vgm.txt
Can you post a screenshot of the error message which you see on the screen?
It sounds like you are running VoiceGuide on an account which is not allowed to run VBScripts. Try running VG when logged in as Administrator.
What is the "tango Access PPPoE Adapter" TAPI device which you are using on this system?
Ah yes, sometimes the anti-virus applications etc will prevent VBScripts form being executed properly... Most anti-virus programs have options that allow you to enable full VBScript execution.
