Guest Guest Report post Posted 07/29/2003 09:59 PM Will not let me access Voice Mail Box Options 165155.97 0 Loading VMB data begin 165155.97 0 Loading VMB data - about to delete old entries 165155.97 0 Loading VMB data - sorting/ordering 165155.97 0 Loading VMB data end 165155.97 0 Loaded new voicemail configuration file (XML) 165217.62 0 callstate OFFERING 66109 0 4 165217.62 0 ring 1 165223.64 0 ring 2 165223.64 0 Answer the call at 7/29/2003 4:52:23 PM 165223.64 0 lineAnswer(66109) => 66092 165223.64 0 callstate ACCEPTED 66109 0 0 165223.69 0 tapi Reply 66092 0 165223.69 0 callstate CONNECTED 66109,0,0 165223.69 0 WorkingModeTAPI= 165223.69 0 WorkingModeScript= 165223.69 0 Inband detection not enabled 165223.69 0 StartLoadedVgs at 7/29/2003 4:52:23 PM 165223.69 0 [start] Playing 165223.70 0 [start] Playing (D:\Hotline\blank.wav) 165223.83 0 PlaySoundStart ok [D:\Hotline\blank.wav] 165223.84 0 RunModule PLAY end 165226.69 0 Play End line[0] (id=194164) 165226.69 0 LsPlayMsg EV_PLAY_FINISHED 165226.69 0 LsPlayMsgFinished EV_TIMEOUT_GOTOMODULE 165226.70 0 [Welcome] Number Input 165226.70 0 [Welcome] Playing (VmailSysWelc.wav) 165226.82 0 PlaySoundStart ok [C:\Program Files\VoiceGuide\Scripts\Voicemail Server\VmailSysWelc.wav] 165238.79 0 Play End line[0] (id=197168) 165238.79 0 LsGetNbrsPlayWelcMsg EV_PLAY_FINISHED 165240.59 0 dtmf * (42,2) 165240.59 0 LsGetNbrsRxDigits * 165240.60 0 RVreplace start (strlen>100) 165240.60 0 RVreplace end: [On {Success} Goto [Voicemail Box ] Return [Welcome] On {Fail} Goto [Voicemail Retrieve]] 165240.60 0 Script Load C:\Program Files\VoiceGuide\system\vm\VmLogin.vgs 165241.50 0 Loaded C:\Program Files\VoiceGuide\system\vm\VmLogin.vgs into:2 165241.51 0 [VmLoginStart] Running VB Script... 165241.52 0 RVreplace start (strlen>100) 165241.57 0 Run Script waiting... (shellid=2088, process=652) 165241.66 0 cl Run_ResultReturn >>[Key_VmMmNewMsgs]{1}[Key_VmMmSavedMsgs]{2}[Key_VmMmAdminGreeting]{3}[Key_VmMmAdm nPin]{4}[Key_VmMmAdminForwardPhone]{5}[Key_VmMmRecMessage]{6}[Key_VmMmGoVmLogin] 8}[Key_VmMmVmExit]{0}[Key_VmMmPlayMessageCounts]{#}[Key_VmRmReplayCurrent]{1}[Ke _VmRmSaveAndPlayNext]{2}[Key_VmRmDeleteAndPlayNext]{3}[Key_VmRmPlayPrevious]{4}[ ey_VmRmPlayCurrent]{5}[Key_VmRmPlayNext]{6}[Key_VmRmPlayMessageInfo]{7}[Key_VmRm oVmLogin]{8}[Key_VmRmExitRetrieveMessages]{0}[Key_VmAdminWelcMsgPlayCurrent]{1}[ ey_VmAdminWelcMsgDeleteAndRecNew]{2}[Key_VmAdminWelcMsgSaveAndReturn]{3}[Key_VmA minWelcMsgDeleteAndReturn]{4}[Key_VmSendMsg_StopRecAndPlay]{1}[Key_VmSendMsg_Del ecAndRec]{2}[Key_VmSendMsg_SaveRecAndAddress]{3}[Key_VmSendMsg_DelRecAndReturn]{ }[Key_VmSendMsg_DelRecAndReturn2]{0}[Key_VmSendMsg_StopRecAndPlayVmSendMenu]{#}[ mbId]{}[VmbLoginIntro]{none}<< 165242.51 0 task completed (shellid=2088, process=652) 165242.51 0 Could not find VGRUNRESULT_0.TXT or SHLRESLT.TXT 165242.51 0 Hanging up call... [WaitTillFinished - next module not specified] 165242.51 0 RecSoundStop ok 165242.52 0 PlaySoundStop ok 165242.52 0 fnHangupCall end 165242.66 0 callstate DISCONNECTED 66109,1,0 165242.66 0 LsAwaitingCalls EV_REMOTEPARTY_DISCONNECT 165242.66 0 Hanging up call... 165242.66 0 RecSoundStop ok 165242.66 0 PlaySoundStop ok 165242.67 0 fnHangupCall end 165242.67 0 callstate IDLE 66109 0 0 Share this post Link to post
SupportTeam Report post Posted 07/30/2003 03:21 AM The module VmLoginStart in script \system\vm\VmLogin.vgs was set to "Wait until Program Completes" instead of the correct setting - which should be: "Wait Until Program Returns Information" Changing that setting will fix the problem. I'm attaching the updated script to this post - please place the file in VoiceGuide's \system\vm\ directory, replacing the previous file. The updated script will make it into next Beta... I think that all VBScript modules in the Voicemail system should be set to "Wait Until Program Returns Information"... vmLogin.vgs Share this post Link to post
