Caller Id
Hello,
I have a problem but I dont know what it causing this problem.
Some times when I am dialing into the ivr-system, the system is getting the color id of the line.
Sometimes the caller id is not showing.
Can this be a vg problem
How can this be fixed?
Thank you
Most likely explanation is that the phone company is not always sending the CallerID.
Could you please post a copy of VoiceGuide's Trace Logs which captures the call when no CallerID is displayed, this will allow us to see what happened on the system and if any CallerID was sent.
[Log]
VoiceGuide=10
NumberLoader=0
VoicemailManager=0
EmailSender=0
TapiWrapOcx=10
SapiWrapOcx=0
Then restart VG and make calls until you see one which is a problem call.
Please post the traces.
Hello Support,
I am wrong. Today I put a line which can retrieve the caller ID.
So you can see the number which dialed in to the system. It is working now.
085958.05 8 rv lg add [$RV_STARTTIME]{11/8/2006 8:59:58 AM}
085958.05 8 rv lg add [$RV_DEVICEID]{8}
085958.05 8 rv lg add [$RV_CIDNAME]{}
085958.05 8 rv ns add [PathApp]{C:\Program Files\VoiceGuide\}
085958.05 8 rv lg add [$RV_CIDNUMBER]{452636}
085958.05 8 rv lg add [$RV_DNIS]{0000}
085958.05 8 rv lg add [DNIS]{0000}
The problem which I had was:
I connected a line at one of the dialogic ports and when I am dialing into the system, the tracelog shows me which line had used to dial into the system.
092834.20 6 rv lg add [$RV_STARTTIME]{11/8/2006 9:28:34 AM}
092834.20 6 rv lg add [$RV_DEVICEID]{6}
092834.20 6 rv lg add [$RV_CIDNAME]{}
092834.20 6 rv ns add [PathApp]{C:\Program Files\VoiceGuide\}
092834.20 6 rv lg add [$RV_CIDNUMBER]{}
092834.20 6 rv lg add [$RV_DNIS]{4582}
092834.22 6 rv lg add [DNIS]{4582}
Thank you for willing to help.
I have a other question:
Can you tell me what these log files are ?
They are in the log directory:
1108vmmgr.txt
1108vgm.txt
1108tw.txt
1108sw.txt
1107es.txt
*vmmgr.txt - Voicemail Manager trace.
*vgm.txt - VoiceGuide application layer trace.
*tw.txt - Telephony layer trace.
*sw.txt - TTS generation trace.
*es.txt - Email sender trace.
