Answering Machine Issue
Hello,
When answering machines pick-up from the voice loader, only the tail end of the message is being recorded. The beginning of the message is cut off.
VoiceGuide does wait until end of the answering machine's welcome message before it starts to play the "Answering Machine" message/script. If the message starts to play prematurely its usually due to the welcome message having a lot of silence at beginning or at end. The VG traces and recorded sound files of what AM message it hears being played will let us see what exactly happened during the call.
[Log]
VoiceGuide=10
NumberLoader=0
VoicemailManager=0
EmailSender=0
TapiWrapOcx=10
SapiWrapOcx=0
Then restart VG and make an outgoing test call which demonstrates the problem.
1113tw.zipHello,
I am using version 6.0.3179
Also, I noticed my issue may be with the live voice detection and not the am. Seems when cell phone voice mail and cable company voice mail answering system pick-up, voice guide think they are live people and starts the message before the recording begins.
I have included the log file
Please let me know what I need to do
Kraig
Trace shows that indeed the Dialogic card reported that it thinks that a live person has answered the call:
130854.81 1 state Live person answered, playing C:\Documents and Settings\administrator.YCOA\Desktop\telephonequality.wav
What you should do is to have a script which begins with a record module that upon finishing recording due to silence goes onto the playing of the message.
This will result in a bit of a pause before playback if a live person just says hello, so actually a better solution may be to have a Play module first which just plays "Press 1 to hear message" once and then goes to the record module. Make sure both the Play and the Record modules have the "on {1}..." path defined in them.
