Does Voiceguide Script Has A Bug?
Hello Support,
I am testing the voice guide script to make an IVR system for our sales department but I cannot give them our product because I am not satisfied with this.
Instead of getting 1 email, the system is sending me 2 emails. The emails are the same.
If a caller press 0 for example, the system is sending 2 emails with the same message and then the systen hans up.
When you press 8, the system is sending 1 message and then it is going to the voicemailbox menu
This is the VmLm.vgs script.
'Script : vmLm.vgs
'Module : VmLmMenu
iLineId = $RV_DEVICEID
sPathSysVoice = "$RV[PathSysVoice]"
sPathDataVm = "$RV[PathDataVm]"
sVmMsgCurr_Path = "$RV[PathDataVm]VmSave\"
sVmbId = "$RV[VmbId]"
sVmLmRec = "$RV[VmLmRec]"
set VG = CreateObject("VoiceGuide.CommandLink")
set Fso = CreateObject("Scripting.FileSystemObject")
'---+----1----+----2----+----3----+----4----+----5----+----6----+----7----+----8----+----9----+----0
select case "$RV_LastKeyPress"
case "$RV[Key_VmLmStopRecAndPlay]" '{1}
'Stop recording and play the recorded message
VG.Script_Goto iLineId, "", "VmLmRecPlay", ""
case "$RV[Key_VmLmDelRecRecAgain]" '{2}
'Delete the recorded message and start recording again
on error resume next
DeleteFile sVmLmRec
VG.Script_Goto iLineId, "", "VmLmStart", "[VmLmRec]{}" 'clear the name of the last recorded message
case "$RV[Key_VmLmSaveAndPlayGreeting]" '{3}
'Save the recorded message and play the greeting message for this voicemail box again
ProcessRecordedVmMsg iLineId, sVmbId, sVmLmRec
case "$RV[Key_VmLmDeleteGoGroupPrevious]" '{4}
'Delete the recorded message and group browse to the previous voicemail box
'and play it's greeting message
'todo
DeleteFile sVmLmRec
case "$RV[Key_VmLmDeleteAndPlayGreeting]" '{5}
'Delete the recorded message and play the greeting message for this voicemail box again
DeleteFile sVmLmRec
case "$RV[Key_VmLmDeleteGoGroupNext]" '{6}
'Delete the recorded message and group browse to the next voicemail box
'todo
DeleteFile sVmLmRec
case "$RV[Key_VmLmSaveGoVmLogin]" '{8}
'Save the recorded message and go to Voicemail Login Menu
VG.Script_Goto iLineId, "vmLogin.vgs", "VmLoginStart", "[VmLmRec]{}" 'clear the name of the last recorded message
case "$RV[Key_VmLmSaveVmExit]" '{0}
'Save the recorded message and exit the voicemail system
'return to wherever the return path was defined to.
VG.Script_Return iLineId, "[VmLmRec]{}" 'clear the name of the last recorded message
case "$RV[Key_VmLmSaveGoLmRecMsgMenu]" '{#}
'Stop recording and play the menu which speaks the options listed above
VG.Script_Goto iLineId, "", "VmLmMenuPlay", ""
case "timeout"
'only happens here after the "Max Rec Length" announcement is played
case else
'unknown - just play the menu then...
end select
Set VG = Nothing
set Fso = Nothing
sub ProcessRecordedVmMsg(iLineId, sVmbId, sVmLmRec)
if sVmLmRec = "" then
exit sub
end if
if (FileMoreThenMinLength(sVmbId, sVmLmRec)) then
VG.Vm_Event iLineId, "FORWARD", sVmbId, sVmLmRec, "", ""
else
VG.Admin_TraceLogAdd iLineId, 2, "vm msg too short, deleting: " & sVmLmRec
DeleteFile sVmLmRec
end if
end sub
function FileMoreThenMinLength(sVmbId, sFilename)
if "$RV[VmLmRec_RecLen100ms]" = "" then
'[VmLmRec_RecLen100ms] not set...
VG.Admin_TraceLogAdd iLineId, 1, "vm RV[VmLmRec_RecLen100ms] not set."
FileMoreThenMinLength = True
exit function
end if
iRecLen100ms = Clng($RV[VmLmRec_RecLen100ms])
iFileLength = iRecLen100ms / 10
iMinLength = Cint(VG.Vm_VmbConfig_Get(sVmbId, "MsgLenMin"))
if iMinLength = "" then
'min length undefined - return true
exit function
end if
if iFileLength >= iMinLength then
else
VG.Admin_TraceLogAdd iLineId, 2, "vm SoundFileLength=" & iFileLength & ", MsgLenMin=" & iMinLength
FileMoreThenMinLength = False
end if
end function
sub DeleteFile(sFname)
'starts a VBScript which is designed to make repeated attempts to delete the file.
Set ws = CreateObject("WScript.Shell")
ws.run "wscript ""$RV[PathVgSys]vm\vm_deletefile.vbs"" """ & sFname & """", 0
Set ws = Nothing
end sub
Can something be done with this script to do the wright things?
I will appreciate it very much because I cannot give our department such a system.
Thank you.
I have the log file
Log.zip
If a caller press 0 for example, the system is sending 2 emails with the same message and then the system hangs up.
Trace shows caller was taken to a voicemail box and started recording a message at 16:00:09:
160009.70 3 state [VmLmRec] Recording C:\Program Files\VoiceGuide\data\VmSave\0001_1113160009_1_3_451300_.wav
The recording was ended by caller pressing the # key about 5 seconds later:
160014.83 3 tw dtmf # (3,35,35)
Which results in caller being taken to the "Record Message Menu", which lets caller listen to recorded message etc.
160014.91 3 state [VmLmMenuPlay] Playing (C:\Program Files\VoiceGuide\system\voice\RecMsgMenu.wav)
aller presses the 0 key while listening to that menu to indicate they wish to exit the Voicemail system:
160016.70 3 tw dtmf 0 (3,48,48)
which causes the call to be hung-up as no return path was specified when jumping to voicemail scripts.
The recorded voicemail file (0001_1113160009_1_3_451300_.wav) is forwarded as soon as the 0 key is pressed:
160016.77 3 vm frwrd vmb 0001 email to 107@tocmail.com (wav attached)
but then upon call being hung up the 'On Hangup' script sends the email again (!)
160017.88 3 vm frwrd vmb 0001 email to 107@tocmail.com (wav attached)
This is a bug. We'll look into this and should come back with an answer in a few hours.
Please place the attached .VGS files into VoiceGuide's \system\vm\ subdirectory. These file will be used when running the software in either the Evaluation mode or the Enterprise mode.
Please try the scenario as before (press 0 while in recorded message menu and then hangup) and please advise if the duplicated forwarding still occurs.
vm_DuplicateForwardFix.zip
Hello Support,
Thanks for the files.
When the caller press 1 it it OK. The caller can listen to his/her spoken message
When the caller press 2 it it OK. The caller can record again
This should be good for a system thats let people leave their problems.
The option to save the message and exit was when you press the key 0. The system should save the message and exit. (very good)
But the problem was that the system was sending 2 emails of the same.
Now with the file you send, VG is existing the system but it's sends no email and no message.
I am getting a message at my screen telling me that the system want to send a message. If I press "yes" no message is sending.
The only problem whas that the system was sending 2 emails.
When the caller press 8, the system send 1 email (very good) but it is going to voicemailbox menu.
Can I leave it so to make the caller press 8 and then hang up? (It is not nice if the caller hear the message regarding voicemail)
It is a problem reporting system. (I am sending you the logs)
log1.zip when I press 8
log2.zip when I press 0
I hope you can help.
Regards.
It should be good
Log2.zip
Log1.zip
Yes, that's what it should be doing... see the voicemail menu specifications for the Leave Message Menu: http://www.voiceguide.com/vghelp/html/voicemailMenus.htm
We can see in the "es" trace that the email sending was attempted, but did not work as in this case it looks like there was a problem with the recorded sound file:
124410.61 0 smtp SendFailed The file you tried to attach does not exist
which is a bit strange as in tw log we can see that it was created:
124406.156 conv out [C:\Program Files\VoiceGuide\data\VmSave\0001_1115124358_1_3_421270_.wav]
Can you check if file C:\Program Files\VoiceGuide\data\VmSave\0001_1115124358_1_3_421270_.wav is on your system?
The forwarding is done at the time DTMF 0 is pressed:
124408.98 3 tw dtmf 0 (3,48,48)
124409.05 3 cl Vm_Event 3, FORWARD, 0001, C:\Program Files\VoiceGuide\data\VmSave\0001_1115124358_1_3_421270_.wav, ,
124409.06 3 vm frwrd vmb 0001 email to 107@tocmail.com (wav attached)
124409.06 0 email sent as plain text as "<HTML" not present in body text (not set to HTML format).
124409.06 3 vm frwrd vmb 0001 end
When the sending though your toc-ftpmail SMTP server fails due the the email sender not being able to find the file on the system, the email sender then looks at the backup sending method - which you've set to be Outlook. And looks like the Outlook installed on this system has protection enabled on it to stop 3rd party applications from sending emails using it... you would need to disable that protection on Outlook.
So the real question is why was the Email sender unable to find the file when sending it through the SMTP server in that case, while it worked in another case (with the same function being used to send the email message)...
I attach a new VgEmailSender.exe to this post. Please place this .exe on your VG directory and reproduce the problem and then send post the "es" trace file (.ZIPed). This new .exe has more tracing in the relevant area to let us see what is happening.
VgEmailSender_6.0.0.zip
Hi Support Team,
I think that I have fixed it.
The caller can press 1 to hear his/her message,
2 to speak again his/her message and
3 to confirm his message and then the system is greating and then end the call.
This is only for the Problem report service system.
If the caller press other keys the system must not response. I have to disable any other key
So I think if I want to use the system for an other service than I have to............use an other script (with the same name) but now it is working.
Just edit the voicemail script(s) to remove the other options then.
Ohhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhh.
I had never think about that option.
I will do that.
Thank you
Have found the cause of "The file you tried to attach does not exist" error.
It was caused by the voicemail scripts supplied previously.
The attached voicemail scripts resolve this issue.
Please place attached .vgs files in VG's \system\vm\ subdirectory.
Then stop VG, delete file EmailQue.mdb from VG's \data\ subdirectory (if the file is there), and then start VG again.
VG will now use the new voicemail script files and the email forwarding should result in only one email being sent.
The VG for Dialogic available for download now (v6.0.3190 and onwards) has these latest voicemail script files included as part of it's download.
vm_DuplicateForwardFix_v2.zip
