Guest ruthy Report post Posted 11/15/2006 07:37 AM Hello, I'm trying to install a D/4PCIUF dialogic card. As I can see in your recommended hardware this type of card requiered "SR5.1.1 + SR5.1.1 SP1 + D4PCIU support patch." combination. I was able to download "SR5.1.1 SP1 + D4PCIU support patch." combination, but I have problems doing it with "SR5.1.1". I tried from "http://membersresource.intel.com/search/ddl/download/DDLResults.asp?Genre=Download%20--%20System%20Release&PKey=Windows%20NT%20Any%20Version&SKey=WinNT%20SR%20v.%205.1.1%20for%20Intel&OrderBy=Ascending&SortBy=Title". It started ok but finally the download window shows a completed message, but it's false. What can I do? Are there any other web location where I can download it? Thank you. Share this post Link to post
SupportTeam Report post Posted 11/15/2006 08:54 AM You should probably contact the Dialogic card supplier... they're the ones responsible for providing you with the drivers so that you can use the card which was sold to you... Share this post Link to post
Guest ruthy Report post Posted 11/16/2006 09:42 AM Hello, I finally downloaded SR5.1.1. I have follow this steps to install my D/4PCIU card: 1. I have installed hardware by following the quick install card instructions. 2. I install SR5.1.1 + SR5.1.1 SP1 + D4PCIU Share this post Link to post
Guest ruthy Report post Posted 11/16/2006 10:08 AM Sorry, I have had problems with connection.... ... as I was saying in the last Post, I followed that steps. When I run DCM, my card is not listed, so I select 'Auto-Detect Devices' option, but it isn´t still listed on it. What could be the problem? Thanks a lot. Share this post Link to post
SupportTeam Report post Posted 11/16/2006 12:19 PM Can you add the card manually? If not then you should contact the Dialogic card supplier from whom the card was purchased.... Share this post Link to post
