How To Make Vg Speaks Voice Files In Another Language
Hi Support,
I am recording voice files in dutch language.
In english you speak "24" as twenty four
In dutch you speak "24" as vier en twintig
Voice guide speaks "24" as twenty four. In the voice files folder you don't have the number "24" but "20" and "4"
If I record the number "4" in dutch and the number "20", Voice Guide is speaking the sound files as:
twintig (waits) and then speaks vier.
How must I do this?
Thank you in advanced.
Regards
from http://www.voiceguide.com/vghelp/html/modSayNumber.htm :
Users can edit the way in which the numbers are spoken, or even add their own Say Number functions by editing the file: lib_num2wav.vbs located in VoiceGuide's \system\vbs\ subdirectory. This is useful if it is required to say numbers/amounts in a language other then English.
Please read the lib_num2wav.vbs file for more information.
Hi Support,
Thank you for the reply. I read the lib_num2wav.vbs file but I can't get it.
I want the system to speak 24 as four and twenty.
In dutch we say vier (4) en (and) twintig (20) : vier en twintig
The system speaks: twintig (20) vier (4).
I looked at this part:
'name : Number
'info : Say the number
'arg1 : Number to be spoken :
Function Number(byval arg1)
'returns a list of comma delimited wav files,
'with each wav file corresponding to a character
'in the supplied input string.
'any commas in the number are ignored - they are deleted before the number is spoken.
sNumberTrimmed = Trim(arg1)
sNumber = replace(sNumberTrimmed, ",", "")
Dim Place(9)
Place(2) = "thousand.wav"
Place(3) = "million.wav"
Place(4) = "billion.wav"
Place(5) = "trillion.wav"
' Position of decimal place 0 if none
iDecimalPlacePos = InStr(sNumber, ".")
If iDecimalPlacePos > 0 Then
sAfterDecimalPoint_WavList = Digits(Mid(sNumber, iDecimalPlacePos + 1, 100))
sNumber = Left(sNumber, iDecimalPlacePos - 1)
End If
If Left(sNumber, 1) = "-" Then
iNumberIsNegative = 1
sNumber = Mid(sNumber, 2, Len(sNumber-1))
else
iNumberIsNegative = 0
End If
iCount = 1
'we will create the WAV list of sound files starting from
'the back of the number.
Do While sNumber <> ""
s3_WavList = hundreds2wav(Right(sNumber, 3))
If s3_WavList <> "" Then
If iCount > 1 Then
s3_WavList = s3_WavList & "," & Place(iCount)
End If
If sNumber_WavList = "" Then
sNumber_WavList = s3_WavList
Else
sNumber_WavList = s3_WavList & "," & sNumber_WavList
End If
End If
If Len(sNumber) > 3 Then
sNumber = Left(sNumber, Len(sNumber) - 3)
Else
sNumber = ""
End If
iCount = iCount + 1
Loop
If sAfterDecimalPoint_WavList = "" Then
if sNumber_WavList = "" then
Number = "0.wav"
else
Number = sNumber_WavList
end if
Else
Number = sNumber_WavList & ",point.wav," & sAfterDecimalPoint_WavList
end if
if iNumberIsNegative = 1 then
Number = "minus.wav," & Number
end if
End Function
I have no idea what to do. Can someone help me please.
Must I changed the whole vbs file?
I do this:
Any help needed please.
I think what you should actually be changing is the tens2wav function.
From your description I think the below version should do it (see the text in bold - that's the only change made :
' Converts a number from 10 to 99 into .Wavs *
Function tens2wav(TensText)
on error resume next
if len(TensText) = 1 then
Result = digit2wav(Right(TensText, 1))
tens2wav = Result
exit function
end if
Result = "" 'null out the s3_WavListorary function value
If CInt(Left(TensText, 1)) = 1 Then
' If value between 10-19
Select Case CInt(TensText)
Case 10: Result = "10.wav"
Case 11: Result = "11.wav"
Case 12: Result = "12.wav"
Case 13: Result = "13.wav"
Case 14: Result = "14.wav"
Case 15: Result = "15.wav"
Case 16: Result = "16.wav"
Case 17: Result = "17.wav"
Case 18: Result = "18.wav"
Case 19: Result = "19.wav"
Case Else
End Select
Else
' If value between 20-99
Select Case CInt(Left(TensText, 1))
Case 2: Result = "20.wav"
Case 3: Result = "30.wav"
Case 4: Result = "40.wav"
Case 5: Result = "50.wav"
Case 6: Result = "60.wav"
Case 7: Result = "70.wav"
Case 8: Result = "80.wav"
Case 9: Result = "90.wav"
Case Else
End Select
sDigitWav = digit2wav(Right(TensText, 1)) 'Retrieve ones place
If sDigitWav <> "" Then
If Result = "" Then
Result = sDigitWav
Else
Result = sDigitWav & ",and.wav," & Result
End If
End If
End If
tens2wav = Result
End Function
Let us know if this is sufficient of of there are other changes that are needed.
