Problem : Inband Signalling With Avaya Ip Office 406
Hi
i'm using a PABX (Avaya IP Office 406) and i need to get the called number to use the proper script
My main problem is that $RV_DNIS and $RV[DNIS] are empty and when trying to get data from inband signaling, i don't get anything.
I don't know exactly what's happening, so i'll post the log i get :
173212,62 4 event callstate OFFERING 4 2,0,0
173212,64 4 script interpretor: VgMulti v6.0.3179
173212,65 4 fired OFFERING event to listeners
173212,65 4 set LineState().hCall = 4 in LINECALLSTATE_OFFERING
173212,67 4 cid CallerID vars set (in 'offering' event) [,,]
173212,68 4 call AnswerTheCallIfAllowed from LINECALLSTATE_OFFERING
173212,70 4 rings=0, min rings before answer=2 (iCallerIdHasArrived=0)
173212,70 4 should answer as inband signaling expected
173212,71 4 rv clear all
173212,73 4 init LineState ResetAtStartOfNewCall.
173212,73 4 answering the call (,,,0)
173212,75 4 timer clear
173212,76 4 tw ring 1
173212,78 4 ring time since last ring event (sec): 0,00
173212,78 4 rings=1, min rings before answer=2 (iCallerIdHasArrived=0)
173212,79 4 should answer as inband signaling expected
173212,81 4 rv clear all
173212,82 4 init LineState ResetAtStartOfNewCall.
173212,82 4 answering the call (,,,0)
173212,84 4 AnswerTheCall pending (called at 173212,75)
173212,86 4 tw DialogicEvent 134,TDX_CST,0,0,0,DE_RINGS,ET_RON,
173212,86 4 event TDX_CST, iCode=134 state=6001
173212,87 4 LsModuleTransition : 134, [TDX_CST]
173213,39 4 tw DialogicEvent 135,TDX_SETHOOK,0,0,0,DX_OFFHOOK,CALL_INBOUND,
173213,40 4 event TDX_SETHOOK, iCode=135 state=6001
173213,42 4 LsModuleTransition : 135, [TDX_SETHOOK]
173213,42 4 event callstate CONNECTED 4 256,0,0
173213,43 4 LineEvCallState_Connected hDevice=4 params=256,0,0
173213,45 4 WorkingModes tapi= script= LineState().iState=6001
173214,46 4 Inband detection start (2 patterns loaded)
173214,48 4 timer set 5 EV_TIMEOUT_INBANDSIGNAL_INTERDIGIT
173214,50 4 tw DialogicEvent 134,TDX_CST,65535,0,0,DE_LCON,,
173214,51 4 event TDX_CST, iCode=134 state=4100
173214,51 4 LsIndialSignalCapture event[EV_UNKNOWN_134] inband[]
173219,89 4 timer fired EV_TIMEOUT_INBANDSIGNAL_INTERDIGIT
173219,89 4 event EV_TIMEOUT_INBANDSIGNAL_INTERDIGIT, iCode=9011 state=4100
173219,90 4 LsIndialSignalCapture event[EV_TIMEOUT_INBANDSIGNAL_INTERDIGIT] inband[]
173219,92 4 StartLoadedVgs at 15/11/2006 17:32:19 (VgMulti v6.0.3179)
173219,93 4 set LineState().iVgsIdx=1
173219,93 4 set sScriptToRunOnHangup=[] in StartLoadedVgs
173219,95 4 init StartLoadedVgs_InitLineState start
173219,96 4 rv add [$RV_STARTTIME]{15/11/2006 17:32:19}
173219,96 4 rv add [$RV_DEVICEID]{4}
173219,98 4 rv add [$RV_CIDNAME]{}
173219,00 4 rvns add [PathApp]{C:\Program Files\VoiceGuide\}
if you need to know anything about my config file or other, don't hesitate to ask
Thank you.
Trace shows that no DTMF tones were sent by the PBX at all after the call has been answered, so looks like the PBX is not sending any Inband Signalling...
