Recorded File Problem
I have a script with a record module that appears to be truncating the filename of the file it records.
The setup is-
windows 2003
voiceguide for dialogic
As it is a dialogic card, two files are saved to the filesystem, eg:
116173146_8_893011822.vox
116173146_8_89301
the second is the wav file. I have added a .wav extension and played it to verify.
the value of the variable that the record module returns is
116173146_8_893011822.wav
Our system does need to use the wav file for other parts of the system, and there is just not enough information to reconstruct the filename.
any ideas.
thanks.
[Log]
VoiceGuide=10
NumberLoader=0
VoicemailManager=0
EmailSender=0
TapiWrapOcx=10
SapiWrapOcx=0
